Calculating Nuclear Cross Section for Materials
The discussion focuses on calculating the nuclear cross section for materials, specifically with a density of atoms at 1026 m-3 and a neutron beam where 0.04% is stopped in a 2 cm slab. The formula used is Sigma = event rate per nuclei / incident flux. Participants explored unit conversions and the relationship between macroscopic and microscopic cross-sections, ultimately leading to calculations that resulted in values like 3.00 x 1057 and 8.00 x 10-34. The importance of maintaining consistent units throughout the calculations was emphasized.
  • Understanding of nuclear physics concepts, specifically nuclear cross sections
  • Familiarity with the formula Sigma = event rate per nuclei / incident flux
  • Knowledge of unit conversions between meters and centimeters
  • Basic grasp of Avogadro's number and its application in atomic density calculations
  • Research the relationship between macroscopic cross-section (∑) and microscopic cross-section (σ)
  • Learn about the attenuation of particles through materials and the relevant equations
  • Study the application of Avogadro's constant in calculating atomic densities
  • Explore practical examples of cross-section calculations in nuclear physics
Students and professionals in nuclear physics, researchers calculating nuclear interactions, and anyone involved in materials science or radiation physics seeking to understand cross-section calculations.
Apollo14LMP
What is the cross section if the density of atoms in a material is 10^26 metres-3, and 0.04% of a beam of neutrons is stopped in a 2 cm slab of the material ?
I have no idea ..
If the density would be 1/meter^3 and 1% would be stopped in 1meter (imagine a cube of 1m side length with exactly one atom in it), can you calculate the cross-section?
Then you just have to scale this to get the original numbers.
Cant really visualise this ... but I guess there would 10^26m-3 with 0.04 % stopped in it ? I need to calculate the barns. Still not sure about the 2 cm mentioned ...
I have gone away and come up with the following -
I have converted the 10^26 m-3 to centimetres = 1.0000^32cm3
I have then calculated using a formula found on the internet
https://facultystaff.richmond.edu/~ggilfoyl/research/CrossSectionIntro.pdf
1.0000^32cm3 x 2cm x 6.022^23 / 0.04 = 3.00 x 10^57
I cannot see where I am wrong but some advice would be a big help
I am assuming you must convert the m-3 to cm3, and calculated my answer as per the research article I found. Thank you
I have no idea ..
Can one write the relationship between the macroscopic cross-section, ∑, and the microscopic cross-section, σ, which is what one wishes to find?
Then write the equation for attenuation of particles passing through a slab of material, i.e., write the equation for dI(x)/dx, where I(x) is the beam intensity as a function of distance from the surface into the material.
The formula uses the density in g/cm^3 and uses the Avogadro constant to convert this to atoms/cm^3. You know atoms/cm^3 so you can skip that step in the formula.
This is easier to see if you work with units everywhere (a good habit in general).
Thank you for your help ..
0.04 % / 1.0000^32cm3 x 2cm = 8.00 x 10^-34
that is N events (0.04%) / beam particles per unit area (1.0000^32cm3 / target particles (2cm)
The units are missing, but apart from that it looks good.
Thanks struggled to solve that you have both been very helpful .. I appreciate your time and trouble so much ..
  • · Replies 18 ·
