Object Traveling Up an Inclined Plane
In summary: Thanks for the explanation.In summary, a monkey is strapped to a sled and both are given an initial speed of 2.0 m/s up a 19.0° inclined track. The combined mass of monkey and sled is 16 kg, and the coefficient of kinetic friction between sled and incline is 0.20. The monkey and sled move a total of .397 m up the incline.
campbellst87
[SOLVED] Object Traveling Up an Inclined Plane
In a circus performance, a monkey is strapped to a sled and both are given an initial speed of 2.0 m/s up a 19.0° inclined track. The combined mass of monkey and sled is 16 kg, and the coefficient of kinetic friction between sled and incline is 0.20. How far up the incline do the monkey and sled move?
Sigma(F) = ma
I drew a free body diagram and found the normal force using Sigma(Fy)=ma.
Normal Force - Weight y = 0
Normal Force = Weight y
Normal Force = (weight)(cos 19)
Normal Force = 148.257 N
I can now find the Force of Friction:
Force of friction = coefficient of friction * Normal Force
Force of Friction = (.20)(148.257 N)
Force of Friction = 29.65 N (In the negative x direction.)
Now I'm stuck. I'm not sure how to apply Newton's laws since there is no force in the positive x direction. Any help is appreciated. Thanks.
Well you could use energy considerations to find how far it travels up the plane. (Conservation of energy)
I was thinking about using (mgh + .5mv^2)initial = (mgh + .5mv^2)final, but I thought this is only true for conservative forces.
I believe I've solved it using energy. Here's what I did (My main equation is in bold):
Work (nonconservative) = (KE(f) + PE(f)) - (KE(i) + PE(i))
Work = F*Delta x
Substituting the latter into the former and getting rid of things that will be zero, I get:
Force*Delta x = (mgh(f)) - (.5mv(i)^2)
Now, using simple trigonometric relationships, I see that Sin theta = h/x. This gets plugged into my main equation, so:
Force*Delta x = (mg(x*sin theta)(f)) - (.5mv(i)^2)
I also know that my only nonconservative force is my friction force, so:
-Force friction*Delta x = (mg(x*sin theta)(f)) - (.5mv(i)^2)
I now have one equation and one unknown, and can solve. Plug in everything:
-29.651 N*Delta x = (16 kg)(9.8 m/s^2)(x*Sin(19)) - (.5)(16 kg)(2 m/s)^2
Simplified and units removed for clarification:
-29.651*Delta x = 51.04x - 32
-80.691x = -32
x = -32/-80.691
Finally:
x = .397 m
Does this look right to you all?
Can anybody comment on whether or not this looks correct?
This does look correct and is a clever way of solving the problem. More commonly, because the combined force against motion up the inclined plane is always constant (friction force you found + force from gravity), you can apply one of the four kinematic equations for constant acceleration.
Your original question was:
When doing these problems, you usually change coordinate axes from the ordinary vertical is y and horizontal is x, to one where the direction of motion (up the plane) is x, and the normal force, which is perpendicular to that motion, is y.
You have done this by using cosine to find how much of the total force from gravity contributes to the normal force and used that to find the force opposing motion up the plane from friction. You also need to use sine to find the force from gravity that is directly opposing movement up the plane.
Then, try to move on from there.
I see. Didn't even think to use kinematics.
What is the definition of an inclined plane?
An inclined plane is a flat surface that is positioned at an angle to the horizontal plane. It is commonly used to reduce the amount of force needed to move an object by increasing the distance over which the force is applied.
How does an inclined plane affect the motion of an object?
An inclined plane changes the direction and magnitude of the force acting on an object. The force is split into two components: one parallel to the plane and one perpendicular to the plane. This allows the object to move up or down the plane with less force than if it were moving on a horizontal surface.
What is the formula for calculating the force required to move an object up an inclined plane?
The formula is F = mg * sin(theta), where F is the force required, m is the mass of the object, g is the acceleration due to gravity, and theta is the angle of the incline.
How does the angle of the incline affect the force required to move an object?
The greater the angle of the incline, the more force is required to move the object. This is because a steeper incline requires the force to be split into a larger perpendicular component, making the parallel component smaller and requiring more force to overcome the perpendicular component.
What are some real-life applications of inclined planes?
Inclined planes are commonly used in everyday life, such as ramps for wheelchairs or strollers, roads on hills, and slides on playgrounds. They are also used in more complex machinery, such as escalators, conveyor belts, and vehicle ramps for loading and unloading. Additionally, inclined planes are used in physics experiments to study the effects of gravity and motion.
