ODE: System of Linear Equations usuing Diff. Operator
The discussion revolves around solving a system of ordinary differential equations using differential operators. The equations provided lead to a relationship of 3x + 5y = 0, which clarifies the constants in the solutions x = 5ce^(-2t) and y = -3ce^(-2t). Participants emphasize the need for precise notation and the importance of maintaining the relationship between x and y, correcting the initial misunderstanding of the constants. The final consensus is that two constants should be used, indicating a correction to the original solution. The clarity gained from the relationship 3x + 5y = 0 is highlighted as crucial for arriving at the correct answer.
RJLiberator
This is an ordinary differential equation using the differential operator.
Given the system:
d^2x/dt - x + d^2y/dt^2 + y = 0
and
dx/dt + 2x + dy/dt + 2y = 0
find x and y equation
Answer: x = 5ce^(-2t)
y = -3ce^(-2t)
We change it into a differential operator equation...
[D^2-1]x+[D^2+1]y = 0
[D+2]x +[D+2]y = 0
We simply cancel values out until we are left with
3x+5y = 0
[D+2]x +[D+2]y = 0
Here we have x = -5y/3 and y = -3x/5
We substitute into the second equation and we can easily find that
x = ce^(-2t)
y = ce^(-2t)
My question is: How does the answer book know that there is a 5 for the x equation and a -3 for the y equation. It seems to me that the constant "c" handles this for me.
Am I doing something wrong to get a less precise answer? Or did I work out this problem correctly.
Thank you.
3x+5y = 0
[D+2]x +[D+2]y = 0
What do you mean by "cancel values". This is a bit sloppy notation. Remember that ##D## is an operator.
Your first equation is telling you that ##3x=-5y##, which is explaining the factors 5 and -3.
RJLiberator said:
x = ce^(-2t)
y = ce^(-2t)
No, this is wrong, since it violates the first equation.
I also recommend that you use Latex to write your equations. It makes them much easier to read.
Likes RJLiberator
RJLiberator said:
Given the system:
and
[D+2]x +[D+2]y = 0
3x+5y = 0
[D+2]x +[D+2]y = 0
Yeah, I'm not following what you did, either.How did you go from the 2nd-order DE to 3x + 5y = 0?
I hope it's obvious that these two equations are equivalent.
Likes RJLiberator
$$(\mathrm{D}^2-1)x+(\mathrm{D}^2+1)y=0\\
(\mathrm{D}^2-4)(x+y)+3x+5y=0\\
(\mathrm{D}-2)(\mathrm{D}+2)(x+y)+3x+5y=0\\
(\mathrm{D}-2)0+3x+5y=0\\
3x+5y=0$$
since the second equation is
$$(\mathrm{D}+2)(x+y)=0$$
RJLiberator said:
x = ce^(-2t)
y = ce^(-2t)
you should have two constants
x = c1e^(-2t)
y = c2e^(-2t)
related by
3x+5y=0
Likes RJLiberator
The key distinction for me in this thread was the relationship of 3x+5y=0. I now see how my answer can be corrected to the final answer as presented in the book.
Thank you guys for the help.
I was very close :p.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 18 ·
