ODE with base excitation caused by a half sine wave
The discussion focuses on solving the ordinary differential equation (ODE) for a car suspension system subjected to periodic half sine wave road bumps. The system parameters include a stiffness of k = 5×106 N/m and an effective mass of m = 750 kg. The displacement response is derived using the superposition principle, resulting in a particular solution expressed as a combination of terms involving sine and cosine functions. The final expression for the displacement response includes a Fourier series representation of the road profile, but participants express uncertainty regarding the verification of the solution for the cosine terms.
  • Understanding of ordinary differential equations (ODEs)
  • Familiarity with Fourier series representation
  • Knowledge of mechanical vibrations and suspension systems
  • Basic calculus, particularly differentiation and integration
  • Study the application of the superposition principle in mechanical systems
  • Learn about the derivation and application of Fourier series in engineering problems
  • Explore methods for verifying solutions to differential equations
  • Investigate the effects of damping in suspension systems and how it alters the response
Mechanical engineers, students studying dynamics and vibrations, and anyone involved in the analysis of suspension systems in automotive engineering.
Dustinsfl
The suspension system of a car traveling on a bumpy road has a stiffness of ##k = 5\times 10^6## N/m and the effective mass of the car on the suspension is ##m = 750## kg. The road bumps can be considered to be periodic half sine waves with period ##\tau##. Determine the displacement response of the car. Assume the damping of the system to be negligible. Hint: The Fourier series representation of the bumpy road, ##y(t)##, is given by
y(t) = \frac{1}{\pi} + \frac{1}{2}\sin(2\pi t) - \frac{2}{\pi}
\Big(\frac{\cos(4\pi t)}{3} + \frac{\cos(8\pi t)}{15} +
\frac{\cos(12\pi t)}{35} + \cdots\Big)
\frac{2}{\pi}
\frac{\cos(12\pi t)}{35} + \cdots\Big) = \frac{2}{\pi}\sum_{j = 1}^{\infty}\frac{\cos(4j\pi t)}{4j^2 - 1}
If I solve each piece separately and use the superposition principle, the first two terms work as solution but I can't verify that the final piece is so I am assuming something is wrong.
\begin{align*}
750\ddot{x} + 5\times 10^6x
&= \frac{1}{\pi} + \frac{1}{2}\sin(2\pi t) - \frac{2}{\pi}
\sum_{j = 1}^{\infty}\frac{\cos(4j\pi t)}{4j^2 - 1}\\
750\ddot{x} + 5\times 10^6x &= \frac{1}{\pi}\\
x_{p1}(t) &= \frac{1}{5\times 10^6\pi}\\
750\ddot{x} + 5\times 10^6x &= \frac{1}{2}\sin(2\pi t)
\end{align*}
Here we will let ##x_{p2} = A\cos(2\pi t) + B\sin(2\pi t)## Then
A\cos(2\pi t)\big[5\times 10^6 - 3000\pi^2\big] +
B\sin(2\pi t)\big[5\times 10^6 - 3000\pi^2\big]
Therefore, ##A = 0## and ##B = \frac{1}{10\times 10^6 - 6000\pi^2}##.
\begin{align*}
x_{p2}(t) &= \frac{1}{10\times 10^6 - 6000\pi^2}\sin(2\pi t)\\
&= \frac{-2}{\pi}\sum_{j = 1}^{\infty}\frac{\cos(4j\pi t)}{4j^2 - 1}
\end{align*}
No matter how I have tried to solve this final piece, the solution doesn't seem to work out though. I end up getting ##A_j = \frac{-2}{\pi(k-16\pi^2j^2m)}## and ##B = 0##. Then
\frac{-2}{\pi(k-16\pi^2j^2m)}\cos(4\pi jt) + 0\sin(4\pi j t) = \cos(4\pi j t - \phi_j)
Therefore, ##\phi = \tan^{-1}(0/A) = 0## and ##R = \sqrt{A^2 + B^2} = \frac{2}{\pi(k-16\pi^2j^2m)}\cos(4\pi jt)##.
x_{p3} = \frac{2}{\pi}\sum_{j = 1}^{\infty}\frac{\cos(4\pi j t)}{k-16\pi^2j^2m}
and
x_p(t) = \frac{1}{5\times 10^6\pi} + \frac{1}{10\times 10^6 - 6000\pi^2}\sin(2\pi t) + \frac{2}{\pi}\sum_{j = 1}^{\infty}\frac{\cos(4\pi j t)}{5*10^6-12000\pi^2j^2}
but I am unable to verify
as a solution so I don't think it is correct.
I think you made a sign error, but otherwise, everything looks fine. How are you trying to verify the solution?
Differentiating twice x_{p3}times m + k times x_{p3} = RHS sum
Dustinsfl said:
$$750\ddot{x} + 5\times 10^6x = \frac{-2}{\pi}\sum_{j = 1}^{\infty}\frac{\cos(4j\pi t)}{4j^2 - 1}$$ No matter how I have tried to solve this final piece, the solution doesn't seem to work out though. I end up getting ##A_j = \frac{-2}{\pi(k-16\pi^2j^2m)}## and ##B = 0##.
You don't need to do the next step of finding a phase angle. You can write down the solution immediately:
$$ x_{p3} = \sum_{j=1}^\infty [A_j \cos(4\pi jt) + B_j \sin(4\pi jt)] = \sum_{j=1}^\infty-\frac{2}{\pi(k-16\pi^2j^2m)}\cos (4\pi j t).$$
Then
$$\frac{-2}{\pi(k-16\pi^2j^2m)}\cos(4\pi jt) + 0\sin(4\pi j t) = \cos(4\pi j t - \phi_j).$$ Therefore, ##\phi = \tan^{-1}(0/A) = 0## and ##R = \sqrt{A^2 + B^2} = \frac{2}{\pi(k-16\pi^2j^2m)}\cos(4\pi jt)##.
The sign error crept in here. You should have gotten ##\phi_j = \pi## because you ended up with R = -A. In fact, you need to be a little more careful. The way you defined R, you have R = |A| because the principal square root is always positive, so depending on the sign of A, R could be +A or -A.
$$x_{p3} = \frac{2}{\pi}\sum_{j = 1}^{\infty}\frac{\cos(4\pi j t)}{k-16\pi^2j^2m}$$ and
$$x_p(t) = \frac{1}{5\times 10^6\pi} + \frac{1}{10\times 10^6 - 6000\pi^2}\sin(2\pi t) + \frac{2}{\pi}\sum_{j = 1}^{\infty}\frac{\cos(4\pi j t)}{5*10^6-12000\pi^2j^2}$$
$$\frac{2}{\pi}\sum_{j = 1}^{\infty}\frac{\cos(4\pi j t)}{5*10^6-12000\pi^2j^2}$$
  • · Replies 16 ·
