ODEs- How to annihilate ln(x) ?
  • Thread starter Thread starter Roni1985
    Odes
The discussion focuses on the method to annihilate the function ln(x) in the context of solving ordinary differential equations (ODEs). Participants suggest that the annihilator can be expressed as (D + xD^2) after initial attempts with D^2 were deemed ineffective. A general method is proposed, which involves transforming the Euler equation into a constant coefficient differential equation by using the substitution t = ln(x). This transformation allows the application of the method of annihilators effectively.
  • Understanding of ordinary differential equations (ODEs)
  • Familiarity with the method of annihilators
  • Knowledge of Euler equations and their properties
  • Proficiency in differentiation and substitution techniques
  • Study the method of annihilators for constant coefficient differential equations
  • Learn about transformations of Euler equations to constant coefficient forms
  • Explore the implications of variable substitutions in ODEs
  • Practice solving ODEs using the substitution t = ln(x)
Students and educators in mathematics, particularly those studying differential equations, as well as mathematicians seeking to deepen their understanding of annihilation techniques in ODEs.
Roni1985
I need to annihilate ln(x)
my try was saying that this is a Euler equation with
r1=r2=0
c1=0 and c2=1
so the annihilator should be D^2
but I don't think it works.
Any other suggestions ?
Thanks.
How about (D+xD^2)?
gabbagabbahey said:
How about (D+xD^2)?
Yep, it works :\
thanks.
But, how did you get it ?
Roni.
I got it by inspection, but if you are looking for a general method, I would say begin by finding Dy(x) and D^2y(x) and seeing if they are proportional to each other.
EDIT: Actually, I don't think you can claim that this is a valid annhilator, since it involves x and is not just a polynomial (with constant coefficients) in D
I see...
thanks very much for the help...
Would it be accurate to say that we check if a finite amount of derivatives are a linear combination?
The method of annihilators is a method for solving constant coefficient DE's. An Euler DE is not that type, but it can be transformed into a constant coefficient DE by a change of variables. Then you can use the method of annihilators on the transformed equation and transform the answer back to solve your original Euler DE. The change of variables you need is t = ln(x). Using a dot for differentiation with respect to t you get, using t = ln(x):
\frac{dy}{dx}=\frac{dy}{dt}\frac{dt}{dx} = \dot y\frac 1 x
\frac{d^2y}{dx^2}= -\frac 1 {x^2}\dot y + \frac 1 x \frac{d\dot y}{dt}\frac{dt}{dx}<br /> =-\frac 1 {x^2}\dot y+\frac 1{x^2}\ddot y
When you substitute these into the left side of your Euler equation you will be left with a constant coefficient equation for y as a function of t. You will need to substitute x = et in the right side too. Solve that by annihilators and substitute t = ln(x) to get your final answer.
