Is Space-Time Dilation Just a Funny Concept or Does It Have Real Properties?
The discussion centers on the nature of space-time dilation and whether it implies that space itself possesses properties or information. Participants debate whether space can be considered "nothing" if it exhibits curvature due to gravity, with some arguing that space should not be viewed as a tangible entity that can stretch or contract. The conversation highlights the distinction between observational phenomena and the physical characteristics of space-time, emphasizing that general relativity predicts effects on measuring rods and clocks rather than on space itself. There is also a focus on the implications of these concepts for understanding the geometry of the universe, particularly in relation to gravitational fields. Ultimately, the thread raises questions about the fundamental nature of space and its relationship to the particles within it.
Adrian2000
Hi all,
I was wondering if anybody else here thinks the concept of space-time dilation/concentration (curvature) is a little bit funny, not in the sense of it having an effect on the neighbouring particles, but in the sense of actually stretching or contracting, as though it itself had certain properties and information, despite being nothing. Or am I missing something, and are the effects of general & special relativities only limited to the particles that experience them? The prime motive for this question, is, as I've said above, that it seems a wee bit difficult to prescribe empty space with information, its own internal set of rules, as, err, it doesn't have anything on which to 'stick' these rules to (it's nothing) - pardon the simplification.
Thank you for the help,
Adrian
Your confusion stems from your mistaken believe that time dilation, for example, is something that is "experienced". It is not. It is an observational phenomena.
You, for example, right now as you are reading this, are traveling at .999999c (relative to an accelerated particle at CERN) and from the frame of reference of that particle, you are MASSIVELY time dilated. Do you feel any different?
Sorry - I don't think you understood what I meant - I did not mean time dilation, I meant space-time dilation, and specifically the contortion of eucledian space to accommodate gravity. (I did not think of the 'time' aspect of space-time, as it's in a different category to the eucledian 'space')
I also don't have a problem with the effects of space-time dilation, but I am scratching my head at the implication that actual space, nothingness, contracts in proportion to gravitational pull.
Adrian2000 said:
Sorry, I don't think you understood what I meant - I did not mean time dilation, I meant space-time dilation, and specifically the contortion of eucledian space to accommodate gravity. (I did not think of the 'time' aspect of space-time, as it's in a different category to the eucledian 'space')
I also don't have a problem with the effects of space-time dilation, but I am scratching my head at the implication that actual space, nothingness, stretches in proportion to gravitational pull.
Ah ... gotcha.
I don't think it's helpful to think of space as a "thing" that gets "stretched/curved/whatever" but rather of spacetime as a framework in which things move according to the geometry caused by gravity.
If space is a "thing" that IS stretched/curved/whatever, then you have to answer what IS this thing that gets contorted.
phinds said:
Ah ... gotcha.
Exactly! I was going crazy thinking that there's something wrong with me for not understanding Einstein's theoretical implications.
And yet, is this not what contemporary Physics is based on? In the sense that if you are right at the edge of the singularity [black hole] about to fall in, you occupy an infitesimally smaller amount of space than you would if you were at the event horizon [despite having the exact same molecular structure, if we assume that you haven't been ripped to shreds by that point]?? Sorry if it's a bad example, but I think you know what I mean.
Adrian2000 said:
Sorry [..] I meant [..] specifically the contortion of eucledian space to accommodate gravity.[..]
[..] I am scratching my head at the implication that actual space, nothingness, stretches in proportion to gravitational pull.
Hi Adrian!
- GR says nothing about space being "nothingness" or not. Einstein interpreted his predictions as that space has physical qualities. Einstein thus discussed the "metrical qualities of [..] space-time".
- GR makes predictions about rods and clocks, not about invisible "space". And measuring rods are not predicted to stretch - nor is gravitational pull a factor!
Instead, according to a distant observer measuring rods are predicted to shrink when moved downwards in a gravitational field, if they are pointing downwards/upwards. You can read it here:
https://en.wikisource.org/wiki/The_Foundation_of_the_Generalised_Theory_of_Relativity
Scroll immediately down to § 22. Behaviour of measuring rods and clocks in a statistical gravitation-field - if you are allergic for the equations you can simply skip them, and only read the plain English conclusions just under (71) and (71a).
Note: as you are there, you may also appreciate just under (72) ! :)
PS: that gravitational pull is not a factor, is currently being explained by means of example D here:
https://www.physicsforums.com/threads/time-dilations-on-confusing-situations.783613/
Hi Harrylin!
Yes, and this is what I meant - IF said measuring rod appears shorter to an outside observer, does it have to do with the actual object (rod) being physically shortened, or does it have to do with space contracting around a gravitational field? And if it is the latter, then clearly this space, nothing IS actually something, and has internal properties, does it not? (according to GR, whether explicitly or implicitly?)
Adrian
Non contorted Euclidean geometry itself is also a set of rules. Doesn't it seem difficult to you, to prescribe empty space with that information?
Not to me, though I could be missing something (which is why I'm here :) ) - prescribing empty space with a system of coordinates doesn't give that space any 'information' as it were, but if we say that that space will warp under certain conditions, hey presto, you have space that has certain internal properties, conditions, etc, that means that whenever it's subject to gravity, it will shrink. Which means that it's not just nothing, which seems a bit off to me.
By the way, I hope I put this thread in the right section :/ (I didn't see a theoretical physics section)
Euclidean geometry is more than that. It tells you for example that the sum of inner angles in a triangle is 180°. Doesn't it seem difficult to you, to prescribe empty space with that information?
Errr, I don't think so. The two examples aren't the same - the triangle doesn't grow to 181 degrees or 179 degrees based on its colour, or whatever external/internal factor you want to compare space-time concentration/dilation resulting from a gravitational field to. Can you elaborate?(To elaborate a bit myself, a triangle being 180 degrees isn't really native to eucledian space; it appears to me, at least off-the-cuff, to be nothing more than an geometric concept deduced through logic and maths - it doesn't actually amount to any information whatsoever in actual, physical eucledian space (not like you can turn eucledian space over and see a sticker saying 'FYI: here's a triangle, this is what it looks like, and its 180 degrees, no more no less!') - plus, we are the ones who decided what a triangle was, and how big a degree was, which means that we are the inventors and sole purveyors of the concept of a 'triangle' - I guess we can have a discussion whether the three dimensions is information in of itself, but it seems that space-time concentration/dilation according to gravity is a little bit different than identifying three axes in empty space. [P.S. And is XYZ also anthropogenic/centric? Hmm, need to read up on my maths.])
So you have no problem with empty space containing the information that triangle angles sum to 180° (Euclidean geometry)? But you have a problem with empty space containing the information for any other value than 180° (non-Euclidean geometry)?
To clarify: Do you have difficulty with space containing...
a) ...any information?
b) ...just specific values?
A.T. I'm not sure what your motivation is here, but all I'm asking is A. whether anybody else has a problem with space-time dilation/concentration (curvature) as it's commonly described in the literature, and/or B. can anybody confirm that I correctly understand said concept of space-time to affect not just the particles present within said 'plane' but also the space of said plane?
Adrian2000 said:
I'm not sure what your motivation here is
I'm trying to pin down where your difficulty lies, in order to address it. Answering my request for clarification would be helpful here.
Is there any conceivable experiment that could tell the difference?
Adrian2000 said:
To elaborate a bit myself, a triangle being 180 degrees isn't really native to euclidian space; it appears to me, at least off-the-cuff, to be nothing more than an geometric concept deduced through logic and maths - it doesn't actually amount to any information whatsoever in actual, physical euclidian space
How would you decide whether there even is an "actual physical Euclidean" space? There's no doubt that we live in some space, but is it in fact Euclidean?
Select three points not all on the same line. Stretch strings tight between each pair of them to create a triangle. Then measure the three interior angles and add them up. This is not an abstract mathematical exercise, it's a direct measurement of something about the physical world that we live in.
The interior angles will not, in general, add to exactly 180 degrees, and the discrepancy will be greater in the presence of stronger greater gravitational fields. Thus we conclude that we do not in fact live in an actual physical Euclidean space (although it's a pretty good approximation for daily life).
Ok, with respect to both AT and Nugatory, enough with the bloody triangles - is there or is there not a warping of space in the presence of gravity? And if so, is that native to the particles that undergo said effects? Or is it native to the space in which said particles exist and they are merely 'passengers'? And if the latter is considered true, then how would one reconcile it with the idea that space is made up of nothing, and thus has no internal conditions (because there's nothing in said space to enforce said conditions)?
Adrian2000 said:
And if the latter is considered true, then how would one reconcile it with the idea that space is nothing, and has no internal conditions (because there's nothing in said space to enforce said conditions)?
How is Euclidean geometry reconciled with this idea?
Jesus AT you can really take the life out of a discussion. Eucledian Geometry is reconciled with the idea of space as nothing in the way that I explained above, in an edit of my 2nd response [to yourself]. The only information that empty space could perhaps have are the three dimensions, and frankly even that sounds dubious, but I don't know sufficient maths to know for sure. Whatever the case, I think the original counter-example remains apt - a triangle doesn't grow to 181 or 179 degrees because it changes colour, or size - but empty space does appear to change if it's subject to gravity.
That alone doesn't imply Euclidean geometry. So how do you reconcile that specific geometry with your idea that space cannot have any information beyond the number of dimensions?
AT, read what I wrote in my second response to you. Eucledian Geometry seems to be nothing more than a logical, mathematical, self-supporting construct existing outside of any actual 'eucledian', three-dimensional space. [read: it exists insofar that we know of it and understand it, like fiat currency (plus understanding)]
@Adrian2k, let me just say that what AT and Nugatory are doing is not being fixated on some irrelevant aspect of the conversation, but trying to make you examine what is meant by space and properties of space. Stopping and reconsidering your biases as to what you intuitively think of as "natural" is essential when dealing with the more exotic physical concepts.
You know this is why nobody talks to you people. I ask one simple question, I get a dozen questions about triangles in return. We can all revise our expectations of what's natural and what isn't in our free time - for now, let's focus - it's Monday and I don't want to waste my time anymore than I want to waste yours.
Non-Euclidean geometries are also logical and mathematical constructs. Euclidean geometry is just one, among an infinite number of possible geometries. Why can empty physical space have that specific geometry, but not any of the others?
Now we're getting somewhere - that's fine, I think, but we are not talking about empty space having non-eucledian geomtries, we are talking about empty space actually contracting or dilating, as though it was physical, and objective.
"Empty space" is not empty. It contains at least a gravitational field, which is nontrivial everywhere. It contains also a lot of other fields. Ok, for all these other fields one can at least say, that the values of the field in vacuum are trivial. For gravity, even this does not make much sense. At best, one can say that what looks like a Minkowski space is undistinguishable by observation from the most trivial state, which we name vacuum.
But, even if one accepts all this - all the fields are there, they have values. One can give them an interpretation, in terms of some ether, if one likes. The mainstream does not like this, and prefers to name them "fields", without any guess which properties such a field describes.
Adrian2000 said:
I ask one simple question, I get a dozen irrelevant questions in return.
Is your question relevant to physics? I asked you twice to name a experiment that would distinguish the two alternatives, and you failed to name one.
Contracted/dilated as compared to what?
Aha! But once again, is it the particles themselves that are affected by said field when they dilate/contract as outlined on the generally accepted model of space-time curvature? Or does it have to do with actual space-time curving? If so, that's fine if there are fields or no fields - space is objective, and is subject to change, with respect to things like gravity, meaning that space isn't nothing, which, as I've said before, seems funny somehow. Do you agree/disagree?
@AT - Dude, I am here because I don't know what I'm talking about and you're asking me to devise an experiment for a concept I do not have a clear understanding of? In which universe does that logic make sense? (and how am I obligated to present you with an experiment upon request?)
@AT 2 - In comparison to its past state, if nothing else. (Compared to space outside of the same gravitational field in the present if you like)
Adrian2000 said:
space isn't nothing
I agree, it isn't nothing. Of course, that does not imply that it is some matter either. Spacetime has a variety of geometrical properties (distance, duration, curvature, etc.). It does not have many properties that we typically associate with matter, such as a rest frame or charge and so forth, but it does have some, such as stress-energy.
Once you accept that it has the properties that it has and does not have the properties it does not have then you will be in a much better position to understand how it actually behaves.
They how do you know that the questions posed to you are irrelevant?
If there is no conceivable experiment that could answer your question, then it's not a physics question.
The geometric model of gravity in GR applies to static gravitational fields as well.
That is a comparison to Euclidean space again. So we actually are talking about Euclidean vs. non-Euclidean geometry.
  • · Replies 20 ·
  • · Replies 25 ·
  • · Replies 94 ·
27K
  • · Replies 30 ·
