One-Way Speed of Light: Is it Possible?
The discussion centers around the possibility of measuring the one-way speed of light, exploring theoretical implications and the challenges associated with synchronizing clocks in different locations. Participants examine concepts related to Special Relativity, time dilation, and the implications of light's speed on our understanding of spacetime.
  • Some participants assert that measuring the one-way speed of light is impossible due to the need for synchronized clocks, which is complicated by time dilation.
  • Others propose that if light travels at C+V in one direction, it must travel at C-V in the opposite direction, questioning the implications of this on our understanding of light and spacetime.
  • A participant suggests that the one-way speed of light could be a superposition of all speeds, raising the question of whether this has been explored by physicists.
  • Some argue that the one-way speed of light is an arbitrary convention and that the two-way speed is invariant and measurable as c.
  • There are mathematical discussions regarding the implications of Einstein's synchronization convention and its applicability in flat versus curved spacetime.
  • Participants express differing views on whether the one-way speed of light is a trivial curiosity or holds deeper significance.
  • Some participants challenge claims about the impossibility of synchronizing clocks, suggesting that Einstein's synchronization can be consistently applied in flat spacetime.
Participants do not reach a consensus on the nature of the one-way speed of light, with multiple competing views presented regarding its measurement, implications, and the validity of synchronization methods.
There are unresolved questions regarding the assumptions underlying the synchronization of clocks and the implications of different models of spacetime. The discussion reflects a range of interpretations of Special Relativity and its foundational principles.
kochanskij
TL;DR
If light travels at C+V in one direction and C-V in the other, could we detect that? How? If not, could this indicate something profound about light and spacetime?
From what I've read, it is not possible to measure the one way speed of light. We must reflect it off a mirror and then divide its travel time by 2, giving us its round trip average speed. Time dilation makes synchronizing two separated clocks impossible. We just assume light goes at C in all directions. (I'm not talking about the speed of its source or detector. Assume everything is in the same inertial frame) Please correct me if I'm wrong.
If it goes at C+V in one direction, it must go at C-V in the opposite direction. We always measure an average speed of C. But we can never know what V is. Could this lead to something profound about light and space and time? Maybe light has no definite one way speed. Maybe it is in a superposition of all speeds. V is every velocity 0 < V < C. Is this possible? Has any physicist explored this? Or is the one way speed of light just a trivial curiosity?
kochanskij said:
TL;DR Summary: If light travels at C+V in one direction and C-V in the other, could we detect that? How? If not, could this indicate something profound about light and spacetime?
The first thing to realize is that measuring the one-way speed of light requires that the clocks at both ends are perfectly and undeniably recording identical times. That opens a can of worms that is not possible to solve.
The next thing to realize is that Einstein's theory of Special Relativity solved some problems for the first time and made predictions (including atomic energy, physics happening slower for fast-moving objects, etc.) that have been convincingly confirmed. So, whatever he needed to assume for that theory is strongly supported.
No.
It indicates that simultaneity is relative. I think that's pretty profound.
That doesn't sound right to me. Do you have a reference for this claim?
Of course. It's a well-understood phenomenon. For at least 100 years, I think.
I'd go with this option. You can choose to use coordinates in which the speed of light is anisotropic. In SR they just make all the maths messier so nobody does so, but you could. However, it's quite common to do in GR because it tends to be more convenient to pick coordinate systems adapted to the geometry of spacetime than worry about whether they're everywhere orthonormal.
No. The two-way-speed of light must be ##c##.
If the distance is ##L## and the light moves with ##c+v## in one direction, because the 4D-reference coordinate-system was defined this way, then the time for both directions is
##t=\frac{L}{c+v}+\frac{L}{u}= \frac{2L}{c}##
Then light must go at
##u= \frac{c+v}{1+2v/c}## in the opposite direction.
Calculation:
https://www.wolframalpha.com/input?i2d=true&i=Divide[L,\(40)c+V\(41)]+Divide[L,u]=2Divide[L,c]
Calculation:
Thank you for your correction. I feel silly that I forgot that you don't find an average velocity by adding the two velocities and dividing by 2. A very basic error on my part.
Sorry to resume this thread. Many times in PF has been discussed that the invariance w.r.t. inertial frames of one-way speed of light is just a matter of simultaneity convention employed to define it. In particular in SR inertial frames are defined in a such way that the one-way speed of light is actually the invariant ##c## (based on the Einstein synchronization convention).
However the two-way speed of light is actually measurable and experimentally it is the invariant ##c## as well.
A problem I see is that it is implicitely assumed that Einstein's synchronization convention can be always applied consistently.
What do you think about ?
No. In flat spacetime it is known that you can always apply Einstein synchronization between clocks at rest relative to each other.
In curved spacetime it is known that you can't always do that, and nobody assumes that you can.
Is it actually an experimental result ?
Where would you go to find a flat spacetime to experiment in?
It's a mathematical result using the known geometric properties of flat spacetime and inertial worldlines.
Ok, so using for instance families of mutually "at rest" inertial worldlines in flat spacetime we can check that Einstein's synchronization convention holds consistently.
Yes.
But when we have 2 orbiting points of reference (say earth and mars or earth and the moon) and we can assert changes in positions of recognizable objects or chemical elements we see on their surfaces , and with reasonable accuracy we know the earth AU distances to these objects, but that the directions are not fixed due to orbits around the sun, how does this not allow us a means to test the equality of c in multiple directions , given what we see from the other surface is a one-way transmission of light ?
If as a null hypothesis we assume the bizarre that in a certain direction c travels at infinity and the reverse at half of 299K meters / sec , I would think we would have to observe some very strange motions upon other planets in our definition of distance and time from a point on earth , because any orbit or lack of staying still would impact the speed of real events in our observations , unless c is not altered by changing directions and it would imply it being possible to observe motion in reverse for rotating objects around you , no?
No, because observable phenomena do not depend on a simultaneity convention.
What do you think would change in the observations you make if you changed your definition of the one way speed of light?
How do you know what time according to your clock the light was emitted from the other surface? Answer: there is no direct observable that tells you that. It's a convention--a simultaneity convention.
You don’t know what time according to your clock the light was emitted from the other surface, but you can calculate the acceleration of falling objects onto the surface of another planet with approximation like we know what we should see is how long something takes that’s falling on planet mars
We can then compare for us how long an object falls from our time A to time B to time C , While knowing we are rotating with respect to mars during within time A time B time C … We can compare the Time A to Time b interval with the Time B to Time C interval to see if positions on things we know the gravity should measure , comply and match between A and B the rates for B to C .
  • Skeptical
This sounds incredibly confused. Why not write down an equation: the one way speed of light = some function of clock and ruler readings.
We can calculate how long it would take by the object's own clock for it to fall to the surface of a planet from a given altitude. That is an invariant, yes. But that's not what you are looking for. You are looking for the time it takes by a distant observer's clock. That requires adopting a simultaneity convention.
This syntax is a mess. I think what you are saying is that you look up Mars surface gravity and calculate how long it takes for a rock to fall 5m or something. Say that's 1s, just for convenience. Then you watch it through a telescope.
The light from the "rock starts to fall" event leaves 1s before the light from the "rock lands" event. So the light from the "rock starts to fall" event arrives 1s before the light from the "rock lands" event, independent of light speed.
If you are considering that Mars might have changed distance to Earth significantly in the time the rock was falling then you are proposing an impractical version of Rømer's measurement of light speed. The answer to that depends on how you account for time dilation and you get the (possibly non-isotropic) one-way speed you assumed in your time dilation calculation. If you assume time dilation is negligible (as Rømer did implicitly, since he predated Einstein by more than two centuries) then you get isotropic light speed.
What you watch through a telescope say on the Earth is the difference in proper time elapsed on a clock attached to the rock between the event "the rock start to fall" and "the rock lands" on Mars surface.
Note that this "elapsed time" is invariant since it is measured by a clock that follows the rock's spacetime path.
Roemer measure the one-way speed of light 350 years ago by timing the eclipses of Jupiter's moon Io from different distances as the Earth orbited the Sun. The measurement has been repeated often with increasing accuracy. No clocks needed.
Rømer calculated the ONE-WAY speed of light in 1676 by observing that the eclipses of Jupiter's moon Io occurred 22 minutes later when Earth was on the opposite side of the Sun from Jupiter than when it was on the same side. He realized that light took 22 minutes for light to travel the diameter of Earth's orbit. By dividing the diameter of Earth's orbit by 22 minutes he calculated the speed of light to be 131,000 miles per second. The same method can be used today to more accurately measure the ONE-WAY speed of light.
What am I missing?
  • Skeptical
Eclipse Chaser said:
No clocks needed.
Jupiter and its moons is a clock. The motion of astronomical objects was the first clock
Romer assumed a synchronization convention where the one way speed was the same in every direction
What am I missing?
see post 2 for a very incomplete list. There has been a lot written on this topic. Besides what is on this forum see especially Reichenbach and Anderson in the peer reviewed literature.
How do you measure "timing" without clocks?
What am I missing?
That is comparing the time it takes when the Earth was near Jupiter in its orbit with the time it takes takes on the other side, farthest from Jupiter. How do you know that time is the same on two "synchronized" clocks at those two locations? The differences may be tiny at the velocities of the Earth, so it may give a fairly good answer for that era, but it turns out that there is no way to know the one-way speed of light with complete accuracy.
What's different in Roemer's methodology is that you don't need a light-speed communication back TO the source to confirm the arrival of a light-speed communication FROM the source. ONE continuously running timer is not functionally the same as "two clocks" that require synchronization. And scale matters. Earth's orbital speed is about 67,000 MPH = 0.0001C, hardly sufficient for relativistic effects to slow down a timer. All imperial measurements have a degree of error, but Roemer's is NOT direction dependent.
You never need that anyway. When you receive a light signal, you don't have to send another light signal back to the source for you to know that you received the signal.
But ONE continuously running timer, by itself, does not tell you the one-way speed of light. You need to assume a synchronization for that. In Roemer's case, he had to assume, as @Dale said, a synchronization that makes the one-way speed of light the same in all directions (more precisely, that does that for someone at rest relative to the barycenter of the solar system). He didn't state this assumption explicitly, but it is implicit in his calculations.
Romer had local clocks here on Earth. And Jupiter’s moon is another clock. So his experiment indeed has two clocks. That is a hallmark of one way speed of light measurements.
In order to convert his observations of these two clocks into a speed, he had to make some assumptions. If you look into the math, one of those assumptions is that the speed of light is the same in all directions. That assumption is a synchronization convention.
It's late, but I can not follow your reasoning when you say "ONE continuously running timer, by itself, does not tell you the one-way speed of light."
Think of it as a single metronome that clicks every time Io disappears behind Jupiter (roughly every 42.5 hours). When earth is far away, the eclipses occur 11 minutes AFTER the click, when earth is near, the eclipses appear 11 minutes BEFORE the click, year after year after year, REGARDLESS OF DIRECTION. Maybe a good night sleep will help me understand exactly what needs to be "synchronized." (Thanks for engaging.)
It requires that one clock, traveling great distances and speed remained exactly synchronized with its original time. IMO, that is a greater assumption that assuming two synchronized clocks. And if everything on Earth that depended on time underwent the same time dilation as the clock did, how would that be detected?
It is a good point that the effect would be very small. But it is still there, even at walking speed. And the effects at speeds approaching c are much greater. So yes, we know the one-direction speed of light to a reasonable accuracy for most applications, but not all.
  • · Replies 93 ·
  • · Replies 42 ·
  • · Replies 36 ·
  • · Replies 72 ·
  • · Replies 25 ·
  • · Replies 146 ·
10K
  • · Replies 42 ·
  • · Replies 45 ·
