Optimization expression Problem
The discussion revolves around solving a homework problem involving the optimization of areas formed by a circle and a square from a wire of length l. The first part requires finding an expression for the total area of both shapes, while the second part focuses on determining the dimensions that make their areas equal. The third part involves differentiating the total area expression to find the maximum and minimum areas, while the fourth part requires a similar approach but for two squares instead of a circle. Key methods include using perimeter and area formulas, as well as calculus for optimization. The discussion emphasizes the need for clarification on these mathematical concepts and problem-solving strategies.
Rola
Hello,
Can you help me to understand the question..Ineed clarification and hints to solve the question..
A circle and a square are to be constructed from a piece of a wire of length l.
1-give an expression for the total area of the square and circle formed.
2-find the radius of the circle and side of the square that make their areas equal.
3-find values of the radius of the circle and side of the square which give the largest and smallest total area.
4-If insted of the circle another square is formed.Find the values of the sides of the square that yeild the largest and smallest total area.
I solve (1) & (2) but I have difficulties on (3) &(4)
we assume that :
length of wire=circumference of circle+perimeter of square
http://www.0zz0.com"
Area of square= a^2
*To know the length of side of square:
perimeter of square=4*a
a= perimeter/4
Area of square= a^2
=http://www.0zz0.com/realpic.php?s=8&pic=2009/05/08/18/425527447.jpg"
Area of circle=pi*r^2
To know the radius:
r= circumference of circle / 2 PI
Area of circle = http://www.up-00.com/"
Total Area=Area of square +Area of circle
=http://www.0zz0.com"
Area of square=Area of circle :
http://www.0zz0.com/realpic.php?s=8&pic=2009/05/08/19/917299630.jpg"
The value of radius and side of square :
http://www.gulfup.com/
(3) Just add the areas, then differentiate it with respect to 'x' and set it equal to 0, and solve for 'x'. That will get either the max or min. Then check the limits (x=0 or x=L). Then you will have both the max and min.
(4) Do the same as (3) but now use the formula for total area of 2 squares.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 24 ·
  • · Replies 59 ·
34K
11K
  • · Replies 24 ·
