lizzie
- 25
- 0
a chord AB of a circle subtends an angle that is not equal to 60 degees at a point C on the circumference. ABC has maximum area. then find A & B in terms of the angle.
chaoseverlasting said:Can you try to find the area of the triangle in terms of the radius of the circle and the angle subtended? If you can do so, then its a simple problem in maximization.
For example, say the radius of the circle is r and the angle subtended at the point C is [tex]\theta[/tex] and the center of the circle is at the point [tex]O[/tex]. Also, the area of the triangle depends on the base and the height of the triangle, for the height to be maximum, the triangle MUST be isosceles for a given base, can you see why?
lizzie said:I feel in an isosceles triangle the base will be less but height will be more so how do we know that the area is maximum.
