Optimizing Forces in Towing: Minimizing FB for a Given Resultant Force
The discussion focuses on optimizing the forces in towing a truck with two ropes, aiming to minimize the force FB while achieving a resultant force of 950 N along the positive x-axis. Participants explore the relationships between the forces FA and FB, including their components and angles, and discuss the conditions under which FB is minimized. The conversation highlights the importance of calculus in finding the angle q that minimizes FB, emphasizing that the forces must be perpendicular to each other for optimal results. The participants also clarify that the approach to solving the problem varies depending on whether FA or FR is known. Ultimately, the conclusion is that the angles must sum to 90 degrees for the forces to achieve the desired minimum configuration.
newbphysic
The truck is to be towed using two ropes. If the
resultant force is to be 950 N, directed along the positive x
axis, determine the magnitudes of forces FA and FB acting
on each rope and the angle q of FB so that the magnitude of
FB is a minimum. FA acts at 20° from the x-axis as shown.
I have no idea where to start because there is only 2 known values so i can't use sine law or cosine law. What's the first step ?
Write the equations for the x and y components of the forces FA and FB. Solve for FB in terms of the angle q. At what q is FB minimum?
FAx = FAcos(20)
FAy = FAsin(20)FBx = FBcos(q)
FBy = FBsin(q)
can you help me with q ?
i know q must make
FBy=-FAy
FBx + FAx = 950
But i don't know how to find it.
Plug in the expressions with the angles for the force components.
FBx + FAx = 950
FBcos(q) + FAcos(20) = 950
FB cos(q) + 0.94FA = 950
FBy=-FAy
FB sin(q) = - 0.34 FA
Now eliminate FA.
ehild said:
Now eliminate FA.
Fb cos(q) + 0.94 Fa = 950
Fb sin(q) + 0.34 Fa = 0
\frac{Fbcos(q)}{0.94} - \frac{Fbsin(q)}{0.34}= \frac{950}{0.94}
Isolate FB.
Fb ( \frac{cos(q)}{0.94} - \frac{sin(q)}{0.34})= \frac{950}{0.94}
Fb = \frac{950}{0.94} / (\frac{cos(q)}{0.94} - \frac{sin(q)}{0.34})
ehild said:
Isolate FB.
Fb is function of q and you need to find the minimum of that function. Have you studied Calculus?
only calculus 1
What is the derivative of a function at a minimum or maximum?
zero
Take the derivative of Fb with respect to q.
derivative of cos and sin will result another sin and cos
what should i do with it?
That expression would be equal to zero. You will be able to solve that equation for q.
The answer : :nb)
hmm,it looks like mission impossible . Do you know another method ehild ?
It is a fraction equal to zero. What do you know about the numerator, if the fraction is zero?
numerator must be zero which means q must be 0 for sine and 90 for cosine
q is the same angle both for sine and cosine. What equation do you have for q?
my guess q must be 135(-225) or 315(-45) because sin and cos have different sign there
Do not ques, solve. What is the equation?
950 sin(q) + 2626.47 cos(q) = 0
OK. divide the equation by cos(q). Replace sin(q)/cos(q) by tan(q). Solve for tan(q).
Likes newbphysic
All right, thanks a lot ehild. :smile::smile::smile:
One more question though, there is other method that says in order for Fb to be minimum it must perpendicular to Fa ? Can you explain why it works ?
I don't think it is true. It must be an other problem. What did you get for q? Are FA and FB perpendicular ?
if i use that method the result is the same. q = 70 degrees clockwise from x.
That method is not correct for the original problem.
so it's just a coincidence that it has the same result ?
The result are not same, only close together. What did you get with my method?
  • #31
70.11 clockwise
  • #32
It should be 71.12 clockwise.
  • #33
950 tan (q) = -2626.47
tan q = - 2626.47 / 950
q =
  • #34
There was some mistakes when we derived FB, and I did not notice.
Next time do the derivation symbolically, and plug in numerical data at the end. In that case, you would have got 70°.
It is true that the two angles add up to 90°.
If the angle of FA is a and the angle of FB is q, and the magnitude of the sum of the forces is F
FAcos(a) + FBcos(q) =F, (we measure q clockwise),
FA sin(a) = FB sin(q) --> FA=FB sin(q)/sin(a).
F_B=\frac{F}{\frac{\sin(q)}{\tan(a)}+\cos(q)}
If you want FB minumum, the denominator should be maximum. Take the derivative of ##\frac{\sin(q)}{\tan(a)}+\cos(q)## and make it equal to zero : ##\frac{\cos(q)}{\tan(a)}-\sin(q)=0##, that is ##\frac{1}{\tan(a)}-\tan(q)=0##
What does it mean for the angles a and q?
  • #35
For FB perpendicular FA,is there an explanation for this ? why it works ? and why not perpendicular to FR ?
Sorry if i ask a lot of questions :)
  • #36
It's easy to see geometrically.
Draw the 950N as a line OP with a length representing its magnitude, and a line for the direction of FA from the same origin.
The magnitude of FA will be indicated by a point on its line, Q say.
FB will be represented by a vector from Q to P. What position of Q minimises the length PQ?
  • #37
It IS the explanation. ##\vec F_R ## is the sum of the vectors ##\vec F_A ## and ##\vec F_B ##. We expressed their components with the magnitudes FA, FB and angles, a, q. Solved the system of equations for FB. It must be minimum, so its derivative with respect to q has to be zero. From that, we got the equation ##\frac{1}{\tan(a)}-\tan(q)=0##, that is, the tangent of the angle q is equal the reciprocal of the tangent of the other angle. Now, remember how the tangent was defined in a right triangle,
##tan(\alpha)=a/b## and ##tan(\beta)=b/a##, the tangents of the two angles are reciprocal to each others in a right triangle. But the sum of the two angles is 90°as the sum of all angles in a triangle makes 180°, one angle is 90° , so ##\alpha + \beta = 90°##. Any time when the tangents of two acute angles are reciprocal, their sum is 90°.
Here, the two forces ##\vec F_A ## and ##\vec F_A ## enclose the angle a+q, and the tangents of the angles are reciprocal to each other, so a+q=90°, the forces are perpendicular to each other.
  • #38
when it's perpendicular to FR ? the red line is the right answer according to calculation
:oldconfused:
OK :wink: but what i still don't understand is this, how can you know it must be perpendicular to FA not to FR. Here is another example that looks exactly like before but in this example Fb perpendicular Fr. Why it's different ?
I tried to use the your method and i find theta = 60 degrees
  • #39
This is an other problem. Here Fa is given, FR has to be determined, so as its direction is the positive x axis. In the previous problem, FR was given and Fa was unknown.
From the equation Fa sin(30)=Fbsin(θ) ---> 2*1/2 = Fbsin(θ), you get that Fb=1/sin(θ), which is minimum if sin(θ)=1, that is, θ=90°.
  • #40
I'm really confused :bugeye:
Why for the first problem i can't solve it like this one (without substituting FA)
FA sin(20) -FB sin(q) = 0
FB =FAsin(20)/sin(q)
I know that we don't know FA but we know in order for FB to be minimum sin(q) must equal 1 (the biggest value) but the result will not be 70
  • #41
:oldconfused:
Neither line minimises the distance PQ, keeping P fixed and varying Q. (Or is P supposed to be where the red line meets the baseline?)
  • #42
P is fixed but Q vary.
Ooh i see so is this mean in order to find minimum value the unknown must perpendicular to each other ?
  • #43
If one has a fixed direction and you are trying to minimise the other, yes.
(I assume Q in the diagram is where the blue line meets the sloping black line.)
Likes newbphysic
  • #44
In the first problem, FR was given, you knew the point P and you had to draw a line to the line of FA, which length was the shortest. It is the normal from P to the line FA. That line segment corresponded to FB, and the red line segment corresponded to FA.
In the second problem, FA was given, you knew the point Q. You have to draw the shortest line from it to the line of FR. It is perpendicular to FR.
You know, that the shortest distance from a point to a straight line is the perpendicular to the given line.
If you drew a line perpendicular from P, its length would be longer than the real FB.
  • #45
Thank you for your help
:bow:
