Optimizing Range in Projectile Motions: Analyzing Launch Angle Graphs
  • Thread starter Thread starter Temper888
The discussion revolves around the relationship between launch angle and range in projectile motion, specifically analyzing graphs that depict this relationship based on an experimental model.
  • Participants explore which graph best represents the relationship between launch angle and range, with some questioning the effect of varying launch angles on range. There is a discussion about the maximum range angle and its implications based on the equation provided.
The conversation is active, with participants sharing insights about the expected behavior of range relative to launch angle. Some guidance has been offered regarding the symmetry of the graph, but questions remain about the impact of different initial and final heights on this relationship.
Participants are considering the implications of varying initial and final heights in the experiment, which may affect the expected symmetry of the range versus launch angle graph.
Temper888
1. Which of the following graphs BEST depicts the relationship between launch angle and range in the experiment?Please explain how you arrived to the answer.
Attached is the graphs and the Experiment model.3.I guessed it to be either Graph B or Graph C, but I am not sure.
What is the angle that you shot the slingshot at?
Do you know what angle to fire a projectile to get maximum range (simplest case!)
I know the maximum range angle would be 45 because of the equation: R=v^2sin2θ/g.
Tayab,
There is no specific angle.The question is asking what happens to the range if the launch is increased? From equation R=v^2sin2θ/g, it can be said that range increases until the angle increases to 45 and then decreases from 45 and above because of sin2θ. The graph for range vs. launch angle should be a symmetrical upside-down parabola for same initial and final heights. However, I cannot figure out how does different initial and final heights as in this experiment affect the symmetry of that parabola?
  • · Replies 17 ·
16K
28K
