Optimum Angle for Object Pulling: A Plot Analysis
  • Context: Undergrad
  • Thread starter Thread starter Joans
    Pull
5 replies · 8K views
Joans
I found interesting to me this topic and tryed to analyze.
http://img505.imageshack.us/img505/6655/49209931.jpg
At which angle it is eseaiest to pull an object?
I got equation
[tex]F=\frac{\mu mg}{cos(\alpha)(\mu tan(\alpha)-1)}[/tex] or [tex]F=\frac{\mu mg}{\mu sin(\alpha)+cos(\alpha)}[/tex]
I don't know this math very well unfortunately, but I would be interested to see a plot:
how mostly optimum angle is dependent from mu, and for example then mu is 1 alpha is 45, and so on...
heh sorry for the paint and spelling...
It depends on mu actually. Think of 2 extreme cases. First, mu is 1 (friction is extremely high). In which case X = Y, the answer is 45 degree as you said. But if mu is 0 (frictionless), the answer is clearly 0 degree (the force required to move the object is close to zero).
I'm not sure though; ha haaa
Mr Peetiya
You're looking for a maximum. Use your calculus brain. How does one find the maximum or minimum of a curve?
I would use calculus if i know how to use it, in school i do not have lessons with it, unfortunately, since I am 11grader. But infact i know quite a lot about it. But still I don't know how to found derirative of the bottom. [tex]f(\alpha)=\mu sin(\alpha)+cos(\alpha) f'(\alpha)=\mu cos(\alpha)-sin(\alpha)[/tex] ?? When to make it to zero and solve it? How to solve what equation when? It's homogenic .. divide by cos alpha and whola? :)
And does best angle depends from [tex]\mu[/tex] lineraly? In fact this topic is quite clear, just math's is not very clear.
Well, you seemed to have gleaned the important part of the derivation anyways.
[tex]f(\alpha) = \frac{\mu mg}{\mu sin(\alpha) + cos (\alpha)}[/tex]
[tex]f'(\alpha) = \frac{\mu mg (\mu cos(\alpha) - sin(\alpha))} {(\mu sin(\alpha) + cos(\alpha))^2} = 0[/tex]
because [tex]\mu mg[/tex] is constant, and the denominator can't be zero, we can simplify this problem a bit by focusing on the only part that can be zero.
So, you see why I thought you did well on calculating the f' you did:
[tex]\mu cos(\alpha) - sin(\alpha) = 0[/tex]
Then
[tex] \mu cos(\alpha) = sin (\alpha)[/tex]
So,
[tex] tan(\alpha) = \mu[/tex]
Then arc tan both sides to get an explicit value for alpha. By analyzing this function, e.g. you can see that if there is no friction mu = 0, the best pull is the directly horizontal pull (i.e. alpha = 0). If you have mu = 1.0 the best pull is at alpha = 45 degrees.
If you don't know calculus, this problem probably seems a little out of your league. But I am fairly confident there is a geometrical approach as well, that is within your limits if you're an intelligent high school student, or a bored undergrad. If you have the time, and are still curious, I'd recommend seeking out that way.
