Orbital velocity of a craft at 4km above the Moon's surface
The orbital velocity of a craft at 4 km above the Moon's surface can be calculated using the formula for circular orbit velocity, ##\sqrt{\frac{GM}{r}}##, where ##G## is the gravitational constant (6.674 x 10-11 m3kg-1s-2), ##M## is the mass of the Moon, and ##r## is the distance from the Moon's center. The mass of the craft is irrelevant to this calculation. For a simpler approach, the escape velocity from the Moon can be divided by ##\sqrt{2}## to obtain a close approximation of the orbital velocity. It is important to note that lunar mascons can cause low orbits to be non-circular.
  • Understanding of gravitational constant (G)
  • Knowledge of the mass of the Moon
  • Familiarity with circular orbit dynamics
  • Basic proficiency in unit conversions (kilograms and meters)
  • Research the mass of the Moon for accurate calculations
  • Learn about lunar mascons and their effects on orbital mechanics
  • Study the concept of escape velocity and its applications
  • Explore advanced orbital mechanics using simulation tools like GMAT (General Mission Analysis Tool)
Aerospace engineers, astrophysicists, students studying orbital mechanics, and anyone interested in lunar exploration and satellite dynamics.
Fred Bobo
What would be the orbital velocity of craft at 4km above moon surface?
Assume a mass of 1,000,000 lb, US.
Astronomy news on Phys.org
For a circular orbit, it's ##\sqrt{\frac{GM}{r}}## where ##G## is the gravitational constant, ##M## is the mass of the body being orbited (here: Moon), and ##r## is the distance from the centre of the body. The mass of the craft doesn't matter.
Find the values on Wikipedia and plug them in. Or, you can make it even easier, and take the escape velocity listed on Wikipedia's page about the Moon, and divide it by ##\sqrt{2}##. The result will be only marginally off.
Thank you.
You want the one in SI units. Use ##6.674*10^{-11}##. You don't really need more significant numbers as it won't make much of a difference. Then use mass M in kilograms and distance r in metres - again, don't bother with too many significant numbers, unless you really feel like it matters to you if the result is very precise.
Thank you. All good now.
Care: Due to the lunar mascons, low orbits are seriously non-circular, unto 'lumpy'...
  • · Replies 58 ·
