Order of classes for a part time student
The discussion centers on the optimal order of classes for a part-time engineering student at the University of Minnesota. The recommended sequence includes taking Physics for Engineers I, followed by Intro to Engineering, then Physics for Engineers II, and finally Multivariable Calculus and Linear Algebra & Differential Equations. Participants emphasize the importance of prerequisites, noting that Physics II typically requires knowledge from Calculus II, while Multivariable Calculus and Linear Algebra can be taken in either order after completing Calculus II. The consensus is to integrate physics courses with engineering classes for practical application of mathematical concepts.
  • Understanding of Calculus II concepts
  • Familiarity with Physics for Engineers I and II
  • Knowledge of Linear Algebra and Differential Equations
  • Basic principles of engineering coursework
  • Research the prerequisites for Physics for Engineers II and Multivariable Calculus
  • Explore effective study techniques for balancing part-time coursework with full-time employment
  • Investigate the teaching styles of professors for the relevant courses
  • Learn about the applications of mathematics in engineering and physics
Part-time engineering students, academic advisors, and anyone planning a career in engineering who seeks to optimize their course sequence and manage their workload effectively.
Jeff Ford
I'm currently attending the University of Minnesota in the evenings, waiting for my wife to finish her Ph.D. I plan on going back for a B.S. in engineering, but I haven't picked a field yet.
I'm currently taking Calc II, and have the following classes left to take before I start full time
Multivariable Calc
Linear Algebra & Diff Eq
I'm trying to decide which order to take the classes in. Should I just go ahead and take all of the math in order, or should I follow up Calc II with both physics courses and then go back to the math? Any advice is appreciated.
I'd mix in some physics classes to get some variety and some practical applications to help motivate the math.
I'd agree with berkeman...
but also critical... check pre-requisites/co-requisites for the different courses and base part of the decision on that, as professors will assuming you have taken -- or are at least concurrently learning -- certain material. Physics II, generally "E&M", might be difficult without Calc II (which is usually a bunch of differentiation/integration practice). But I think Calc III (vector calculus) and Diff EQ were both meaningless until I related it to the physics.
Thanks for the advice. I'll finish Calc II this semester, and then I'll probably stick with the following sequence, taking 1 course per term.
Physics I
Physics II
Multivariable Calc
After that I should have enough knowledge to pick a specialization. My wife will be done with her Ph.D. by then, so I'll be able to start full time.
I concur with berkeman, especially if one is planning a career in engineering as opposed to mathematics. It helps to apply the math one learns in engineering and physics courses.
While one is undecided, it would be a good idea to take as many physics courses in addition to engineering, since much of engineering is based on physics.
If th classes are like the ones at most schools, I would take them in this order for a part time schedule:
Physics I
Physics II & Intro to Engineering (I am sure the engineering class is real easy)
Multivariable CalcWhen you say multivariable calc do you mean the standard calc 3 course at most universities? Because at my school Calculus 3 and Linear Algebra are prerequisistes for Multivariable Calculus.
I don't have the time to take more than 1 class per term, since I work a full time job. Taking physics and intro to engineering at the same time would be 11 hours a week of class in addition to 40 hours at my job. Too much for a married man. I put intro to engineering in between the two physics classes because it's only offered in the fall. Plus, while it doesn't look hard, intro to engineering looks pretty time consuming, with learning hand drafting, Pro/engineer, and a robot design project.
For the math classes, Multivariable and Linear Algebra & Diff Eq are the 3rd and 4th lower division math courses for all math, physics, and engineering majors. As long as you've got Calc 2 finished you can take them in either order.
Jeff -- sounds like you are doing good planning. sometimes if the plan allows for flexibility... you can also look into the professors who are teaching the different options... and take classes from those that you have had and feel are particularly good at mentoring your academic growth. and huzzah!.. yea!... both for pursuing your own degree and balancing things as your wife completes her schooling!
Screw the order, ask around and take the classes with the hardest teachers you can find. Order is not important at this point. In fact, I would recommend taking the math before the physics.
The prereq should be:
PhysicsI (mechanics) - concurrent enrollment in calc II.
PhysicsII (e&m)- calc III or diff eq.
physics III (waves, optics, modern physics)
Intro to engineering is a joke course. At this stage, you really don't have much choice of what order to take things.
Ya man, that intro to engineering course is going to be really easy compared to the physics classes.
  • · Replies 19 ·
  • · Replies 32 ·
  • · Replies 19 ·
  • · Replies 21 ·
