Ordinary differential equations and BVP
The discussion focuses on solving a boundary value problem (BVP) for the partial differential equation (PDE) given by Ut - Uxx = e^(-2t)sin(πx/L) with boundary conditions U(0,t) = 0 and U(L,t) = 0, and initial condition U(x,0) = sin(πx/L). The method of separation of variables is employed, leading to the trial solution U(x,t) = X(x)T(t). The basis functions are calculated as Xn = √(2/L)sin(nπx/L) for n = 1, 2, with eigenvalues λn = -((nπ)/L)². The final solution is expressed as U(x,t) = [c1sin(ax)exp(-a²t) + sin(ax)exp(-2t)/(a²-4)].
  • Understanding of partial differential equations (PDEs)
  • Familiarity with boundary value problems (BVPs)
  • Knowledge of eigenfunction expansion methods
  • Proficiency in separation of variables technique
  • Study the method of separation of variables in depth
  • Learn about eigenfunction expansion techniques in solving PDEs
  • Explore the implications of non-homogeneous boundary conditions
  • Investigate the stability and convergence of solutions to BVPs
Mathematicians, physicists, and engineers working with partial differential equations, particularly those focused on boundary value problems and eigenfunction methods.
akanksha331
Solve BVP by separating variables and using eigenfunction expansion method
PDE:Ut-Uxx=e-2tsin(pi x/L) U=U(x,t),x(0,L)
BC1:U(0,t)=0
BC2:U(L,t)=0
IC:U(x,0)=sin(pi x/L)
U(x,t)=X(x)T(t),X''=(lambda) X ,lambda is the separation of parameter.
I have calculated the basis functions as Xn=root(2/L)sin((n pi x) /L) for n=1,2 and labdan=-((n pi)/L)2
Please help to solve the problem
BC1:U(0,t)=0
BC2:U(L,t)=0
Your PDE is not homogeneous. You have:
<br /> u_{t} - u_{xx} = e^{-2t} \sin\frac{\pi x}L<br />
Let's try looking for a separable solution u(x,t) = X(x)T(t). Substituting that into the PDE, we get
<br /> T&#039; X - T X&#039;&#039; = e^{-2t} \sin\frac{\pi x}L<br />
Oh dear. Dividing by XT isn't necessarily going to give us terms which are functions of a single variable and whose sum is a constant, so the standard method doesn't work (or rather, we are forced to make particular choices for X and T in order to do that, and those choices don't lead to a solution of the PDE).
But if we look at the initial and boundary conditions, we see that the initial condition is a constant multiple of \sin \frac{\pi x}L and the boundary conditions require that u vanish at points where \sin \frac{\pi x}L vanishes. This suggests that we should try X(x) = \sin \frac{\pi x}L.
Make a trial solution e^(-2t)*F(t)*G(x)
That will remove one part of your problem.
I am a little unsure if I have the correct approach but here goes
U(x,0) = X(x)T(0) = sin(pi*x/L) (the initial condition)
Let a=pi/L then X(x) = sin(ax)/T(0), Here, X(0)T(t) = X(L)T(0) = 0 (the boundary conditions)
Substituting this back in the original equation gives:
d/dt[T(t)]*sin(ax) + T(t)*sin(ax)*a^2 = exp(-2t)*sin(ax)*T(0)
Solving this gives:
T(t) = c0*exp(-a^2*t) + T(0)*exp(-2t)/(a^2-4)
U(x,t) = X(x)*T(t) = [ c1*sin(ax)*exp(-a^2*t) + sin(ax)*exp(-2t)/(a^2-4) ]
Is the answer correct? How to use eigen function expansion method ?
