Understanding the Relationship between Orthogonal and Unitary Groups
  • Context: Graduate
  • Thread starter Thread starter LagrangeEuler
    Group Orthogonal
The discussion centers on the relationship between the special orthogonal group, denoted as ##SO(2)##, and the unitary group ##U(1)##, particularly regarding their representations. The matrix representation of rotations in ##\mathbb{R}^2##, given by \begin{bmatrix} \cos \theta & \sin \theta \\ -\sin \theta & \cos \theta \end{bmatrix}, is classified as irreducible when viewed as a real representation and reducible when considered as a complex representation. The confusion arises from the distinction between real and complex vector spaces, with the representation being irreducible in the real case and reducible in the complex case due to the nature of the underlying field. The standard representation of ##SO(2;\mathbb{R})## is irreducible, while its complexification leads to a reducible representation in ##GL_2(\mathbb{C})##.
  • Understanding of group theory, specifically special orthogonal groups (##SO(n)##).
  • Knowledge of matrix representations and their properties.
  • Familiarity with real and complex vector spaces.
  • Basic concepts of linear algebra, including diagonalization of matrices.
  • Study the properties of special orthogonal groups, focusing on ##SO(2)## and its representations.
  • Learn about the concept of reducibility and irreducibility in the context of group representations.
  • Explore the relationship between real and complex representations, particularly in linear algebra.
  • Investigate the implications of complexification of representations in group theory.
Mathematicians, physicists, and students studying group theory, linear algebra, and representation theory, particularly those interested in the applications of orthogonal and unitary groups.
LagrangeEuler
I'm a little bit confused. Matrices
\begin{bmatrix}<br /> \cos \theta &amp; \sin \theta \\<br /> -\sin \theta &amp; \cos \theta<br /> \end{bmatrix}
##\theta \in [0,2\pi]##
form a group. This is special orthogonal group ##SO(2)##. However it is possible to diagonalize this matrices and get
\begin{bmatrix}<br /> e^{i\theta} &amp; 0 \\<br /> 0 &amp; e^{-i \theta}<br /> \end{bmatrix}=e^{i \theta}\oplus e^{-i\theta}.
It looks like that ##e^{i\theta}## is irreducible representation of ##SO(2)##. However in ##e^{i\theta}## we have complex parameter ##i## and this is unitary group ##U(1)##. Where am I making the mistake?
There is no mistake. It depends on the field, i.e. whether you allow complex scalars or not. The angle ##\theta## represents likewise a rotation or a complex number on the unit circle. Your choice. Or a real number if you forget about the group structure.
The two groups are isomorphic.
Thanks. I am a bit confused because if I want to speak about rotation in ##\mathbb{R}^2##. Is then
\begin{bmatrix}
\cos \theta & \sin \theta\\
\end{bmatrix}
reducible or irreducible representation of ##\textrm{SO}(2)##? Because every element I can but in block diagonal form that includes complex numbers in the diagonals.
\begin{bmatrix}
\end{bmatrix}
Which dimension does the representation space have in this example?
It is two-dimensional representation. If I understand the question correctly.
LagrangeEuler said:
Is then
\begin{bmatrix}
\end{bmatrix}
This is reducible as a complex representation and irreducible as a real representation.
Thanks. But how to know if I have a complex or real representation of ##\mathrm{SO}(2)##? If the vector space is real is then representation real?
Yes, a representation of a group ##G## here means a homomorphism ##\rho:G\to GL(V)## where ##V## is a vector space. You say that the representation is real or complex when ##V## is a real or complex vector space.
As real rotation we have only one coordinate ##\theta## hence it is one dimensional and therefore cannot be reducible. No dimensions available.
Why that? If it is a complex vector space we still have only one complex dimension: ##U(1)##.
I mean that the standard representation ##SO(2;\mathbb{R})\to GL_2(\mathbb{R})## is irreducible, but the standard representation ##SO(2)\to GL_2(\mathbb{C})## given by viewing elements of ##SO(2;\mathbb{R})## as complex matrices is reducible. The second representation is the complexification of the first.
fresh_42 said:
As real rotation we have only one coordinate hence it is one dimensional and therefore cannot be reducible. No dimensions available.
The group ##SO(2;\mathbb{R})## is 1-dimensional. That does not mean that all its real irreducible representations are 1-dimensional.
Infrared said:
I mean that the standard representation ##SO(2;\mathbb{R})\to GL_2(\mathbb{R})## is irreducible, but the standard representation ##SO(2)\to GL_2(\mathbb{C})## given by viewing elements of ##SO(2;\mathbb{R})## as complex matrices is reducible. The second representation is the complexification of the first.The group ##SO(2;\mathbb{R})## is 1-dimensional. That does not mean that all its real irreducible representations are 1-dimensional.
Sure, but he asked about a rotation matrix, and then the angle is all we have.
@fresh_42 I don't understand your comment. The OP question as I interpret it is whether the standard (real) representation of ##SO(2)## is irreducible and why it isn't a problem that these matrices are diagonalizable over ##\mathbb{C}.##
@LagrangeEuler I'll also add that you have to do a little bit more work to see why the complex standard representation is reducible- what you have written down isn't enough because the change of basis matrix you use depends on which matrix in ##SO(2;\mathbb{R})## you're using. Given a representation ##\rho:G\to GL_n(\mathbb{C}),## it is definitely possible for every matrix ##\rho(g)## to be diagonalizable without the representation itself being reducible.
I thought he meant the one parameter group operating on itself, not as rotation of ##\mathbb{R}^2##. My mistake.
  • · Replies 26 ·
