Orthogonal Projection onto XY plane
In summary, the conversation discusses finding the equation of the orthogonal projection onto the XY plane of the curve of intersection of two particular functions. The suggested method is to set z=0 in the parametric equations of the curve. However, this does not work and instead the two surfaces should be intersected first before projecting onto the xy-plane. The resulting projection is a curve, specifically an ellipse.
brendan
65
I have an assignment question to find an equation of the orthogonal projection onto the XY plane of the curve of intersection of twp particular functions.
If some one knows of a good web page that might explain this to me I would be greatly appreciate it.
regards
Brendan
If you can write the equation of the curve of intersection as parametric equations, just set z= 0. That is, if the curve is given by x= f(t), y= g(t), z= h(t), its projection onto the xy-plane is x= f(t), y= g(t), z= 0.
The two functions that intersect are:
z = y^2 and z = 4-X^2 -y^2
z = 4-X^2 -y^2
As parametric
x = 4-cos(t) y = -sin(t)
z = y^2
As parametric
z = sin(t)
Do I have to combine the two Equations?
Those are NOT parametric equations for the two surfaces. Since they involve only a single parameter they are equations of curves, not surfaces.
The two surfaces are [itex]z= y^2[/itex] and [itex]z= 4- x^2- y^2[/itex]. In this particular case, you don't need parametric equations at all. You can just eliminate z from the two equations to get the projection onto the xy plane.
Just to understand Ivy's answer better, check that the vector in the projection
is actually orthogonal to the xy-plane: describe the xy-plane in "coordinates"
(i.e., in the same way as describing the x-axis as the set of points (x,0) ) , and then
find the coordinates of your vector : coordinates (x,y,z) of intersection point -
coordinates (x,y,z) of projection . You can use dot product to show that the
projection is perpendicular : xy-plane is perp. to the vector going from :
intersection point to image of orth. projection. (It would help if I could draw pictures.)
The two surfaces are z = y^2 and z = 4-X^2 -y^2
surface 1 (xy plane) = (0,y,0)
surface 2 (xy plane)= (x,y,0)
They both intersect at (0,y,0)
is Y the projection?
Sorry, I'm getting confused.
4-x^2 - y^2 =z
y^2 = z
Subtract one equation from the other gives
4-x^2 -2y^2 = 0
Is that the orthogonal projection?
Yes, that is correct.
In your previous post you projected the surfaces first (you should have gotten (x,y,0) for both surfaces btw) and then intersected their projection. That doesn't work. You have to intersect first and then project.
That's exactly what you did in your latest post. Usually you would have to set z = 0 to get the projection. However, since we already have a description of just the x- and y-coordinates of the intersection that does not depend on z, we can skip this step.
By the way, what does the answer look like geometrically?
It looks like a convex Elliptic paraboloid
No, the projection of the curve of intersection of two surfaces into the xy-plane is a curve in the xy-plane, not a surface.
Your first surface, [itex]z= y^2[/itex] is a "parabolic cylinder", your second surface is, [itex]z= 4- x^2- y^2[/itex] is an "elliptic paraboloid" (or, more correctly, a "circular paraboloid". The intersection of the two is given by [itex]y^2= 4- x^2- y^2[/itex] or [itex]x^2+ 2y^2= 4[/itex], an ellipse.
1. What is orthogonal projection onto the XY plane?
Orthogonal projection onto the XY plane is a mathematical operation that involves projecting points or objects onto a two-dimensional plane, specifically the XY plane. This means that the points or objects are "flattened" onto the XY plane, with their original positions and distances preserved relative to each other.
2. What is the purpose of performing orthogonal projection onto the XY plane?
The purpose of performing orthogonal projection onto the XY plane is to simplify and analyze objects or data that exist in three-dimensional space. By projecting onto a two-dimensional plane, it becomes easier to visualize and manipulate the data or objects, making it a useful tool in various scientific fields such as engineering, computer graphics, and physics.
3. How is orthogonal projection onto the XY plane calculated?
Orthogonal projection onto the XY plane can be calculated using a mathematical formula that involves the dot product of the point or object's position vector and the normal vector of the XY plane. The resulting value is then used to determine the new coordinates of the projected point or object on the XY plane.
4. What are some real-world applications of orthogonal projection onto the XY plane?
Orthogonal projection onto the XY plane has many practical applications, such as creating 2D maps from 3D terrain data, creating 2D blueprints from 3D models in architecture and engineering, and generating 2D images from 3D medical scans. It is also used in computer graphics and animation to display 3D objects on a 2D screen.
5. Are there any limitations to orthogonal projection onto the XY plane?
While orthogonal projection onto the XY plane is a useful tool, it does have some limitations. One limitation is that it can only be used on objects or data that exist in three-dimensional space. It also does not account for perspective, so objects may appear distorted or skewed in the projection. Additionally, it may not accurately represent curved or complex surfaces when projected onto a flat plane.
  • Linear and Abstract Algebra
  • Topology and Analysis
