Oscillating mechanical systems. find maximum velocity and acceleration ?
7 replies · 13K views
bensm0
Oscillating mechanical systems. find maximum velocity and acceleration !?
A mass of 0.3 kg is suspended from a spring of stiffness 200 N m–1. If the mass is displaced by 10 mm from its equilibrium position and released, for the resulting vibration
A) Calculate maximum velocity
B) Calculate maximum acceleration
I need help with this please, for starters is the amplitude 0.01m?
Thanks
Yes, amplitude is correct, you must have had some training :smile:. Welcome to PF. There are a ton of googleable resources out there. Check them out, give the problem a try and come back with some specific questions.
Ok thanks
I think I've got it now
using:-
v=- ωA sin(ωt - φ)
a= - ω2A cos(ωt - φ)
And the maximums occur when sin(ωt - φ)=1 and cos(ωt - φ)=1
Thanks again!
omega = square root (k/m) = 25.82
a) 0.001 x 25.82 x 1 = 0.2582 m/s
b)0.001 x 25.82^2 x 1 = 6.6667 m/s^2
Anybody care to have a go at the last question:-
d) the mass required to produce double the maximum velocity
calculated in (b) using the same spring and initial deflection
I get an answer of 0.075kg
Thanks
Thanks
would this not be 0.15kg?
ω = √k/m = 200/0.15 = 36.51
b)0.001 x 36.51^2 x 1 = 13.33 m/s^2 = double Vmax
I know this is a late response to a question but i have the same question and want to check my working.
(thanks in advance)
Eddievic,
I got the same answers as bensm0,
If you double the answer that you got in a) 0.5164
use that in your equations and transpose for mass.
i think :)
justadaftspark said:
Eddievic,
i think :)
I believe you are correct my paper came back and mine was incorrect the paper was an overall pass though so I have not investigated it fully.
