Oscillation problem with damping
A mass on an elastic cord oscillates with an initial amplitude of 23 cm, and the problem involves determining the new amplitude after the system's energy is reduced to half due to damping. The relationship between energy and amplitude is crucial, as energy is proportional to the square of the amplitude. The correct formula to find the final amplitude after energy reduction is Af = Ai/√2. The discussion highlights confusion regarding the equations and the impact of damping on oscillation, ultimately clarifying that the energy reduction leads directly to the amplitude change. Understanding this relationship is key to solving similar problems in oscillatory motion.
azagaros
A mass on a long elastic cord oscillates with an amplitude of 23 cm. If the energy of this system is reduced by fiction to half its value, what will be its amplitude?
Looking though my book or resources on the internet have not revealed a path for this one: I assume I have Ai= 23 cm. E0 = 1/2KAi2et0/T
is the assumption of the equation i am starting with and I am looking for .5E0 so I can find Af
The starting logic is not coming together and any help would be appreciated.
You need the relationship between the total energy stored in the system and the amplitude of the oscillations.
The equation you have tells you how the stored energy varies with time for a strongly damped system... but the answer is in there. Maybe you can use it too - what is the time when the energy is reduced to half?
[edit: nah, easier the other way: how does energy depend on amplitude?]
pedantic aside: damping ... "dampening" would be the process of making it slightly wet.
I not sure how to calculate the time it would be at half energy and I had that thought too. I do not have mass and I am starting with the amplitude of the oscillation. I have been reading my book back and forth trying to figure this one out. Energy does not depend on amplitude. Amplitude is the result of energy expenditure in the conservation of energy thought. It decreases over time due to the work of friction, or air resistance of the mass plus the mass of the cord acting on itself, is my supposition.
This is not getting me any closer to a direction of equations. If potential energy is the pull on the cord to produce the initial amplitude as described as mgy-1/2ky2 = 1/2ky2 + 1/2mv2 would get me the first cycle but not the dampening section nor do I have time in the equation. I do not have a spring constant muchless any indication of time in this structure for a function of amplitude vs time. This all assumes this is a vertical structure. The masses do not cancel out. The oscillation dampening equation is y(t) = Ae bt/2mcos(ωt+φ) and ω = √(k/m - b2/4m2) = √(ω2-b2/4m2). These need some assumption of 0 in them for the start of the system.
Really? You should be able to solve for this sort of problem:
At ##t=0##, ##E_0 =\frac{1}{2}KA^2## ... for ##t>0##, ##E(t) = \frac{1}{2}KA^2e^{t/\tau}## So when ##E(t)=\frac{1}{2}E_0## - solve for ##t##.
But if you look closely at the equation for ##E_0## - what sort of relationship is it between E and A? Is it a cubic relationship? A logarithmic relationship? What?
You do not need the cycles or anything. If you have the system oscillating with amplitude A0 - how would you find E0, the energy stored?
Thread title now changed.
the actual answer was Af=Ai/√2 when I talked to my teacher.
Good - do you know how to get that answer?
  • · Replies 131 ·
