Oscillators and conservation of energy
The discussion revolves around the equations related to spring oscillators, specifically focusing on the derivation and interpretation of energy conservation principles in oscillatory motion. Participants explore the relationships between velocity, displacement, and energy in the context of spring oscillators.
  • Some participants question the origin of the equation v0=√(C/M)*x and seek clarification on its terms and context.
  • Others assert that the equation is related to the total energy of a spring oscillator, which consists of kinetic and potential energy components.
  • One participant mentions a typo in their previous post regarding the equation and attempts to correct it.
  • There are discussions about the integral involved in deriving energy expressions, with some participants expressing confusion over the steps taken.
  • Some participants highlight discrepancies in the interpretation of the equations, particularly regarding the relationship between velocity and displacement.
  • One participant suggests that learning LaTeX would be beneficial for typesetting equations clearly.
  • There are conflicting interpretations about the correct form of the equations and the assumptions made regarding the variables involved.
  • Participants express uncertainty about the implications of certain equations and their derivations, leading to further questions and clarifications.
Participants do not reach a consensus on the interpretations of the equations or the derivations involved. Multiple competing views remain, with ongoing confusion and corrections regarding the mathematical expressions and their meanings.
There are limitations in the discussion, including missing assumptions about the variables, potential misunderstandings of the equations, and unresolved mathematical steps that contribute to the confusion among participants.
velvetmist
In the equation 7.4, the author is taking v0=√(C/M)*x, and I don't get where does that come from. I would really appreciatte your help, thanks.
Could you please define the terms in the equation you posted? This is for a spring oscillator, right? Thanks.
Can you say what you think is being expressed with this equation? What is the total energy of a simple spring oscillator made up of?
And you posted equation 7.5.
Sorry, I made a typo, I posted the correct one.
Yes.
Yes.
It doesn't say much, cause it's trying to explain spring oscillators in a general way.
velvetmist said:
v0=√(C/M)*x
Maybe I missed it, but I don't see this in any of the stuff you posted.
If you do the integral you got:
. Then -M*v02=C*x2. So v0=√(-C/M)*x.
Edit: i just realized i forgot to put the minus.
velvetmist said:
If you do the integral you got: View attachment 231123. Then -M*v02=C*x2. So v0=√(-C/M)*x.
If you are going to post typeset equations, it would be worthwhile to learn a little LaTeX. Info => HowTo => https://www.physicsforums.com/help/latexhelp/
For example, $$\frac 1 2 Mv^2 - \frac 1 2 Mv_0^2$$
$$ -M v^2_0 = C x^2 .$$ Therefore $$ v_0 = \sqrt {\frac {-C} {M}} x .$$
Btw, the text defines ##w_0 = \sqrt {\frac {C} {M}}, v_0 = w_0 A \cos(\phi). ## Then if ##v_0 = \sqrt {\frac {-C} {M}} x, x = A \cos(\phi). ## But we got that ## x = A \sin(\phi),## so ##\cos(\phi)## would be equal to ##\sin(\phi)## and that's not true. And even if it were true, I'm not taking into account that ##w_0 = \sqrt {\frac {C} {M}},## and not equal to ##\sqrt {\frac {-C} {M}}.##
Okay, now that I have figured out that I have a copy of the text (used in the first mechanics course I took all those decades ago), maybe we can have a discussion.
I don't understand what you mean when you write
velvetmist said:
If you do the integral you got ##\frac{1}{2} Mv^2 - \frac{1}{2} Mv_0^2 =##.
Do what integral? Also, this only half of an equation!
velvetmist said:
Then ##-M v^2_0 = C x^2##
I don't see how you got this.
Equation (7.5) in the text is
$$\frac{1}{2} Mv^2 + \frac{1}{2} Cx^2 = \frac{1}{2} M \left( \frac{dx}{dt} \right)^2 + \frac{1}{2} Cx^2 = E,$$
where ##E## is the constant ##\frac{1}{2} CA^2##. Here, ##C## is the spring constant and ##A## is the amplitude of oscillation..
This means that
$$\frac{1}{2} Mv^2 + \frac{1}{2} Cx^2 = \frac{1}{2} CA^2$$
at all times ##t##. Setting ##t=0## gives
$$\frac{1}{2} Mv_0^2 + \frac{1}{2} Cx_0^2 = \frac{1}{2} CA^2,$$
so that
$$v_0^2 = \frac{C}{M} \left( A^2 - x_0^2 \right) = \omega_0^2 \left( A^2 - x_0^2 \right).$$
Also, I do not understand
velvetmist said:
But we got that ## x = A \sin(\phi)##
Actually, ##x = A \sin \left( \omega_0 t + \phi \right)##.
(5.12) integral. And yes, i just realized that I cropted it in a wrong way, but basically: $$\Delta T = \frac 1 2 Mv^2-\frac 1 2 Mv_0^2.$$
Cause we have that
$$\Delta T = \frac 1 2 Mv^2-\frac 1 2 Mv_0^2 = \frac 1 2 Mv^2-\frac 1 2 Cx^2,$$
and that's only true if ##−Mv_0^2=Cx^2.##
I'm just taking that from the textbook. I already posted that part but i will do it again if that helps u:
velvetmist said:
Cause we have that
I agree with
$$\Delta T = \frac 1 2 Mv^2-\frac 1 2 Mv_0^2 ,$$
but I do not understand the second equals sign, I do not understand why
$$\Delta T = \frac 1 2 Mv^2-\frac 1 2 Mv_0^2 $$
is also equal to
$$\frac 1 2 Mv^2-\frac 1 2 Cx^2 .$$
No, you have not taken it from the textbook. You wrote (and used)
which is incorrect, and which is not in the textbook.
George Jones said:
I agree with
$$\Delta T = \frac 1 2 Mv^2-\frac 1 2 Mv_0^2$$
is also equal to
Sorry, sorry, I'm really sorry, i just made a lot of typos, I meant
$$\frac 1 2 Mv^2+\frac 1 2 Cx^2 .$$
That's because
$$ \Delta (T+V) =\Delta E = \frac 1 2 Mv^2-\frac 1 2 Mv_0^2,$$
cause here ##\Delta V=0.## And we also know that
then
$$\frac 1 2 Mv^2-\frac 1 2 Mv_0^2 = \frac{1}{2} M \left( \frac{dx}{dt} \right)^2 + \frac{1}{2} Cx^2.$$
Sorry, i just didn't read "at t=0", which is a huge mistake, but even like that i think is kind of weird cause he have that
$$ v_0 = \sqrt {\frac {C} M} A \cos(\phi) = \sqrt {\frac {-C} M}x .$$
And we know that
$$x = A \sin \left( \omega_0 t + \phi \right).$$
Then
$$v_0 = \sqrt {\frac {C} M} A \cos(\phi) = \sqrt {\frac {-C} M} A \sin \left( \omega_0 t + \phi \right).$$
$$\sqrt {-1}\cos(\phi)=\sin \left( \omega_0 t + \phi \right).$$
I probably made a mistake, or something like that cause i find this equation really weird.
velvetmist said:
That's because
No,
$$\Delta V = \frac{1}{2} C x^2 - \frac{1}{2} C x_0^2 .$$
See equation (5.20).
George Jones said:
No,
Thank you so much! I finally get it, all of my questions were between pages 149 and 150. We will see conservation of energy in three classes, that's why I was so confused about that.
  • · Replies 21 ·
  • · Replies 30 ·
  • · Replies 51 ·
