Oscillatory solution for a given Lagrangian
  • Thread starter Thread starter Siberion
    Lagrangian
5 replies · 2K views
Siberion
Consider the following Lagrangian:[tex]L = \frac{m}{2}(x'^2+y'^2+z'^2) + \frac{q}{2}(xy'-yx')[/tex]
Where q denotes a charged particle.
a) Find the equations of motion
b) Find the solution for z
c) Find the solution in the x-y plane, and prove that it corresponds to an oscillatory motion along both axes.
Considering the Euler-Lagrange equations, the solution for coordinate z is given by:
d/dt (mz') = 0
Thus, a solution for z corresponds to a uniform linear motion along z axis.
For x and y, I get the following systems of dif. equations:
mx'' - qy' = 0
my'' + qx' = 0
I tried solving this system by integrating and substituting,
i.e. mx'' = qy' /integrate
mx' = qy + C
x' = qy/m + C
Substituting, we get
y'' + y(q^2)/(m^2) = C
The inverse process could be done to get an equation for x.
Which I do not think is the right answer, and I don't know how many laws of mathematics I violated while doing that. Could anyone please show me what is the right procedure to solve this system of equations?
Also, I have the impression this Lagrangian corresponds to a charge q interacting with an electromagnetic field. It would be great if anyone could explain me a little bit further about that.Any help would be greatly appreciated.
Thanks a lot.
Siberion said:
mx'' - qy' = 0
my'' - qx' = 0
Should both equations have a negative sign in the left side?
Sorry, my bad, I missed a minus sign in the second equation, then the system becomes:
mx'' - qy' = 0
my'' + qx' = 0
Following the same process I mentioned before, equation for y becomes:
I'm not sure of your math background. If you've had a course in differential equations, then you know that the general solution to this type of equation is y = yh + yp where yh is the general solution of the homogeneous equation y'' + (q/m)2y = 0 and yp is any particular solution of y'' + (q/m)2y = C.
I'm sorry if this becomes too obvious. I've taken Dif. Equations, but my math background is a bit blurry at the moment, because I've just re-taken classes. Once I recall the methods things go easier.
I can see that the solution for the homogeneus equation is indeed an oscillatory motion, both for x and y. I'm having trouble about what to do with the particular solution since I don't have any initial condition.
Would you say that the method I applied to solve the problem is correct?
Thanks for your help.
Yes, your method is a correct way to do it. You've found the general solution to y'' + (q/m)2y = 0. Now you just need any particular solution to y'' + (q/m)2y = C. You should be able to this by inspection. You do not need initial conditions here.
