How to Determine Mole Fraction and Mass Percent from Osmotic Pressure Data?
The discussion focuses on calculating mole fraction and mass percent composition from osmotic pressure data involving a mixture of sucrose, MgSO4, and KNO3. The osmotic pressure of the solution is given as 1.25 atm at 25 degrees Celsius, with a specific concentration of 0.32 weight/volume% and 15% weight/weight of KNO3. The participants clarify the roles of weight/volume% and weight/weight% in the context of the problem, emphasizing the importance of understanding these concepts for accurate calculations.
  • Understanding of osmotic pressure and its formula: Osmotic pressure = Molarity x Gas constant x Temperature in Kelvin
  • Knowledge of weight/volume% and weight/weight% definitions in solution chemistry
  • Familiarity with molarity calculations and conversions
  • Basic grasp of stoichiometry and mixture composition
  • Study the calculation of molarity from osmotic pressure data
  • Learn about the differences between weight/volume% and weight/weight% in solution preparation
  • Explore stoichiometric calculations for mixtures involving multiple solutes
  • Investigate the application of colligative properties in solution chemistry
Chemistry students, educators, and professionals involved in solution chemistry, particularly those working with osmotic pressure and mixture calculations.
Mia Vel
When 0.32 weight/volume% of sucrose, MgSO4 and KNO3 mixture is dissolved in 997 g of H2O, the osmotic pressure at 25 deg Celsius is 1.25 atm. Calculate the mole fraction and mass percent composition of the original mixture if it contains 15% weight/weight KNO3.
2. Homework Equations
Osmotic pressure= Molarity x Gas constant x Temperature in Kelvin
I was able to solve for the molarity of the solution. After it, I don't know what to do next. Can someone please teach me what the next step is and what is the role(meaning) of weight/volume % and weight/weight % in the problem? Thank you in advance. :)
I have no idea what it means.
My friend told me that when you multiply the given percentage by 100, you will get the total mass of the mixture. I am just not sure whether I should believe him or not.
Doesn't sound correct to me. 30% sulfuric acid doesn't always weight 3000 (and 3000 of what? stones? grams? ounces? pounds?).
10K
