OUNT OF ENERGY LOST IN COMPTON SCATTERING EXPERIMENT
The discussion centers on calculating the incident energy of X-rays in a Compton scattering experiment, where a 1% reduction in energy occurs after scattering at 90 degrees. Bob initially used the equation dL=h/mc (1-cos angle) to derive a wavelength change of 2.43 E-12 m but ended up with a quadratic equation that led to incorrect conclusions about energy. A correction was provided, emphasizing that the final energy E_f equals 0.99E_i, and the relationship between initial and final wavelengths should be derived using the Einstein relation E = hc/λ, avoiding quadratic terms.
  • Understanding of Compton scattering principles
  • Familiarity with photon energy calculations using E = hc/λ
  • Basic knowledge of quadratic equations
  • Concept of non-relativistic electron recoil
  • Study the Compton wavelength shift formula in detail
  • Learn about the implications of energy conservation in photon interactions
  • Explore the relationship between energy and wavelength in quantum mechanics
  • Investigate the effects of scattering angles on energy loss in X-ray experiments
Physics students, researchers in quantum mechanics, and professionals working with X-ray technology will benefit from this discussion, particularly those focused on energy calculations in scattering experiments.
Bobster
Any ideas how to do this question ?
In a Compton type experiment X-rays scattered through 90 degrees suffered one percent reduction in energy.What was the incident energy of the X-rays ? You can assume that the electron coiled non-relativistically.
Any help would be really appreciated ! :smile:
Bob
Oh by the way,i used the equation :
and i got dL=2.43 E -12
Since the energy reduction is 1 % i did
hc/L-hc/L' =0.01
and L'=L+2.43 E -12
so we end up with a quadratic :
L^2 - (2.43 E -12)L-(4.83 E -35)=0
Solving I got, L= O or -2.43 E -12
Hence incident energy is hc/0 or hc/-2.43 E -12
=> energy =infinity or hc/(-2.43 E -12). :confused:
Now is this total rubbish,or am I getting somewhere ? :bugeye:
Cheers for any help !
Bob
I believe you made an error when calculating the final energy (and hence wavelength) of the X-ray. Do it like this. The final energy of the X-ray E_f = 0.99E_i where the i stands for "initial". Now use the Einstein relation for the energy of a photon: E = \frac{hc}{\lambda} to figure out the relationship between the final and initial wavelengths of the X-rays. You shouldn't get any type of quadratic term in \lambda
Thanks mate ! that was exactly my mistake.I can't believe I made that error :cry: but oh well !. :rolleyes:
Cheers again !
This world needs more people like :approve: you
Bob
I think the key is to get the recoil angle of the electron. It is almost 45 degrees (tan\theta = .99). Plug that into the Compton formula and you will get the magnitude of the wavelength change. That change represents a loss of one percent of the original energy.
AM
  • · Replies 18 ·
