Outdoor wired networking advice
  • Thread starter Thread starter TheRascalKing
    Networking
6 replies · 3K views
TheRascalKing
Hello all,
so I'm sick of connecting wirelessly from my router (in the bottom, rear, west corner of my house) to the room where I do all of my work (the top, front, east corner). I decided I'm going to run a cable along the outside of the house and into the work room.
The cable will not be buried, and I'm worried about it being subject to the elements. It will be about 150 feet, and as I understand it, there isn't any serious performance loss until about 200 feet or more, so that shouldn't be a problem.
So far, it seems to me like a cable like this one should do the job:
http://www.rakuten.com/prod/150ft-outdoor-waterproof-cat6-ethernet-cable-direct-burial/211959042.html
However, before I go and spend my money, I want to make sure this is the right tool for the job.
Other than installing it along the house, is there any additional steps that I would have to take to ensure durability? Would I have to worry about grounding and lightning strikes?
Thanks
EDIT: I should probably also mention where I live, in case climate makes a difference. I live in the Greater Philadelphia Area, so we get a little bit of everything weather-wise, but nothing too extreme.
If the house's electrical wiring is in good shape, perhaps a pair of powerline networking adapters would do the trick.
WD Livewire Powerline AV Network Kit
Linksys Powerline AV 4-Port Network Adapter Kit (PLSK400)
I've been considering getting one of these two models, to allow me to stream video faster between my computer at one end of my house to the audio/video setup at the other end. I now have to use a wireless extender (a second Apple Airport Express unit) to cover the distance and punch through the intervening walls.
Maybe the OP could move the router one room or two closer toward the the top, front, east corner?
What about a lightning strike?
Burying your cable will expose you to all sorts of undesirable side effects that will be difficult to service without replacing the cable. Most wireless routers easily have a range of a hundred or more feet. At worst, you might need a repeater.
