Overly large Python Jupyter Notebook (.ipynb) files
  • Topic: Python
  • Thread starter Thread starter WWGD
    files Python
12 replies · 10K views
Homework Helper
TL;DR
For some strange-seeming reasons, some of my Python files are extremely larger than others with similar content
Hi all,
I was looking up my virtual file manager in Python Jupyter and in the listing of notebooks; all similar to each other in size and scope , some files
stand out in terms of size for no apparent reasons. I have some 40 notebooks ; all- but- 2 ranging from 10kb to 284kb at the extremes , and two others, notebooks as well, with the same .ipynb extension with sizes 77.3 mb and 91mb respectively. As I said, the latter two are very similar to the other 38: regular notebooks with Python code. Why would these two files be so much larger than the other 38?
EDIT: I hope its ok to post an additional question in the same post:
How do we do a Ctrl +alt+ Delete within a Python Notebook? The think is this notebook is part of
a virtual back end server and not part of the physical machine.
WWGD said:
Summary:: For some strange-seeming reasons, some of my Python files are extremely larger than others with similar content
Hi all,be so
Do the large ones contain images from e.g. matplotlib?
Windows, Linux, iOS...? Also how did you start Jupyter - from the command line, Anaconda Navigator...?
Try visiting http://localhost:8888/tree#running in a browser and selecting 'shutdown' on the appropriate process.
If Windows: try switching to the terminal window running the Jupyter Notebook process with Alt-Tab then hit Ctrl-C.
When you save the notebook, it saves the output of all of the cells, which may include large amounts of data or images. That's why the files are so large. If, before you save the file, you go to the Kernel tab and click "Restart and clear output", it will clear all of the output in the cells. Then when you save it, you will just be saving the code in the cells, not the output, which will probably make the file much smaller.
Thank you for your reply. I am using Windows 10 and not quite from either of your options. I enter 'Jupyter' into the search box, then the OS accesses the command line and gives me access through localhost 8888. I don't have any plots at all, I don't use anything other than python proper in my overly large files.
My largest python source code file (of 55 different source code files) is 2 KB. For my purposes of merely learning python syntax I don't need or use any IDE -- I open a Win 10 command prompt window and run python.exe from that window.
I am too used to the Jupyter notebook interface. But , thanks, I will consider that.
So does the http://localhost:8888/tree#running -> Shutdown method work for you?
There is no virtual machine involved, just jupyter running in the background running your python programs in a shell and a web server as an interface.
This code will generate a pretty large .ipynb file:
[CODE lang="python" title="Infinite loop"]while True:
print(1)[/CODE]
Thanks, my bad. I meant a virtual server at local host. Thanks for the suggestion. I haven't gotten to my pc yet, will let you know.
print(1)[/CODE]
Hmm.. I am remembering now I did several copies ( for practice) of an algorithm to print all primes in a given range. It was from 2 to around 10,000. Maybe that explains it.
Still nothing virtual. It's all running in the same Windows kernel in multiple processes spawned by the Jupyter server.
Ya think :wink:?
If you change the extension to .json and open it up in a browser you will probably be able to see all those primes. Change back to .ipynb to open up again in Jupyter.
Thanks again. Upon checking, I realized these were the days before I became (a bit more ) proficient with indentation issues Let's just say I have Ctrl+ C etched into my nervous system, to stop way too many infinite loops. Sadly, I am often still too impatient to sit down and write up the flowchart :(., so I keep repeating these indent mistakes at times. This means some of the prime printouts wrote out the same prime more than once. If I was disciplined-enough I would try to figure out the logic flaw. Will do it by this weeks end, when I will look into indenting more carefully. Thanks.
