What are the oxidation numbers in [Re2Cl9]2- and how can it exist?
  • Thread starter Thread starter kankerfist
    Oxidation
The oxidation numbers in the complex ion [Re2Cl9]2- can be understood through the concept of bond order and the nature of oxidation states. In this case, the oxidation state of rhenium (Re) can be considered as 3.5, which allows for the existence of the ion despite the unconventional fractional oxidation state. The discussion highlights the importance of recognizing that oxidation numbers serve as an accounting tool rather than a strict representation of chemical properties.
  • Understanding of oxidation states and their calculation
  • Familiarity with bond order concepts in molecular chemistry
  • Knowledge of redox reactions and half-reaction balancing
  • Basic proficiency in LaTeX for chemical notation
  • Research the concept of bond order and its implications in molecular structures
  • Learn about fractional oxidation states and their significance in coordination chemistry
  • Study redox reaction balancing techniques, focusing on half-reactions
  • Explore the use of LaTeX for chemical equations and notation in academic writing
Chemistry students, researchers in coordination chemistry, and anyone involved in redox reaction analysis will benefit from this discussion.
kankerfist
Sorry about no latex, when I try using latex my formulas just wind up as a link
that says "LaTeX graphic is being generated. Reload this page in a moment."
Anyway, I was trying to balance a redox equation and I am completely stumped
as to how:
[Re2Cl9]^2-
can be possible. I'm aware that some arrangements can cause the same atoms
in an ion to have different oxidation numbers, but I can't seem to figure out how
that molecule can exist under any arrangement. Any hints would be appreciated
Chemistry news on Phys.org
as to how:
[Re2Cl9]^2-
To help with latex, I've seen that message when i try to preview a post but if i actually make a post then it will show up. Sometimes I make an error in my latex and i can just edit it real fast. Just try to post some latex and not preview see if that works.
unless you get this error then you really did something wrong
\LATEX
Ok, I'll test it by quoting someone that used it sucessfully.
^{33}_{17}Cl^{16}\xrightarrow{n,n}~^{31}_{15}P^{16 }+~^4_2He^2
There You Go. Now see if you can edit your first post with some good code!
Im looking forward to your work!
Edit: You the man
{ReCl}_5} + {{H_2}O}
{Re_2}{Cl_9}^{2-} + {ReO_4^-} + {Cl^-} + {H^+}
as to how:
[Re2Cl9]^2-
It's possible for atoms to have a charge that isn't a whole number, or the number can be very different from what is expected. For example, what is carbon monoxide, CO? Does the oxygen have 4 bonds? Does the carbon have 2 bonds? Do they compromise to make 3 bonds each? (edit: I looked it up and yes they make 3 bonds each).
The number of bonds between atoms or groups of atoms is called the Bond Order.
From that link "A good example of this is bonds between carbon in the molecule benzene where the delocalized molecular orbitals contain 6 pi electrons over six carbons essentially yielding half a pi bond. Together with the sigma bond the bond order is 1.5"
Is it possible that Re has a bond order of 3.5? Sure, why not? :smile:
Ok, finally figured it out above. I am trying to balance this equation, and in order to break it into half reactions, I need to know the ox #'s of each atom to see which is the reduction half and which is the ox half. If the Re is 3.5 like you say, then am I on the right track that the oxidation half reaction is:
2 ReCl5 + 3e- --> {Re_2}{Cl_9}^{2-}
edit: sorry, I mean reduction half
The best approach is to assume that oxidation numbers are just an accounting device and they don't refer to any real chemical property.
  • · Replies 18 ·
23K
