Parallel axis theorem + rotational inertia
The discussion revolves around calculating the rotational inertia and kinetic energy of a system consisting of two particles and two rods, using the parallel axis theorem. Participants emphasize the importance of correctly applying the theorem to find the distance from the rotation axis to the center of mass for each component. There is confusion regarding the mass of the rods and the proper way to sum the rotational inertias of the rods and particles. Ultimately, the correct approach involves treating the rods and particles separately while ensuring that the parallel axis theorem is applied accurately. The conversation highlights the complexities of rotational dynamics and the need for careful calculations in physics problems.
lemonpie
Two particles, each with mass m = 0.85 kg, are fastened to each other, and to a rotation axis at O, by two thin rods, each with length d = 5.6 cm and mass M = 1.2 kg. The combination rotates around the rotation axis with angular speed w = 0.30 rad/s. Measured about O, what are the combination's (a) rotational inertia and (b) kinetic energy?
http://www.lowellphysics.org/beta/Textbook%20Resources/Chapter%2010.%20Rotation/Problems/c10x10_12.xform_files/nw0536-n.gif
parallel-axis theorem: I = Icom + Mh^2
rotational inertia for thin rod: I = 1/12ML^2
K = 1/2Iomega^2
Inet = Irod1 + Iparticle1 + Irod2 +Iparticle2
Inet = 1/12Md^2 + Md^2 + 1/12M(2d)^2 + M(2d)^2
help!
Think more carefully about applying the parallel axis theorem to the rods.
Inet = 1/12Md^2 + Md^2 + 1/12(2M)(2d)^2 + 2M(2d)^2 ?
In your formula for the parallel axis threorem, h means distance
from O to the center of mass.
This is d/2 for the inner rod and 3d/2 for the outer.
oh. h means distance from O to com. not just d.
Inet = 1/12M(1/2)d^2 + md^2 + 1/12(2M)(3d/2)^2 + m(2d)^2 ?
Nope.
You can take each rod separately (as you seem to be trying to do),
or you could treat them as one single rod.
You are muddling these two approaches.
sigh. i guess i would like to treat them as one rod. so this is my answer (i noticed that i wrote a wrong number, so I'm fixing it here):
Inet = Irod1 + Iparticle1 + Irod2 + Iparticle2 = 1/12M(1/2)d^2 + md^2 + 1/12(2M)(3d/2)^2 + m(2d)^2
i think the particles are okay, but not the rods. is that right?
Yes the particles are fine.
But look at the parallel axis theorem again. you don't seem to be applying
it.
And the mass of the outer rod isn't 2M is it?
sorry, i had class. okay, how about this?
Inet = Irod1 + Iparticle1 + Irod2 + Iparticle2 = (M/12(1/2)d^2 + Md^2) + md^2 + (M/12(3d/2)^2 + Md^2) + m(2d)^2
actually, why do you have to use the parallel axis theorem here? why can't you just add up the rotational inertias for rods and particles? someone please help me out soon! thanks!
davieddy said:
In your formula for the parallel axis threorem, h means distance from O to the center of mass.
David
Because the rotation is about O, not the c of m.
Icom = 1/12 ML^2
where L is the length of the rod
so... d/2 and 3d/2 are for the Mh^2 not Icom? that seems weird to me. wait let me try.
Inet = Irod1 + Iparticle1 + Irod2 + Iparticle2 = (M/12 d^2 + M(1/2 d)^2) + md^2 + (M/12 d^2 + M(3d/2)^2) + m(2d)^2
lemonpie said:
inet = irod1 + iparticle1 + irod2 + iparticle2 = (m/12 d^2 + m(1/2 d)^2) + md^2 + (m/12 d^2 + m(3d/2)^2) + m(2d)^2
BINGO!
Nearly. But the mass of the rods is M not m.
lemonpie said:
okay, but this problem:
https://www.physicsforums.com/showthread.php?t=116823
rotation is about point A, and it doesn't require parallel axis theorem.
In that problem the rotational inertia of the rod about point A is given. You don't have to calculate it at all.
sorry! I'm trying to understand!
In that problem, the moment of inertia of the rod about A was given
in the question.
Try this one:
Using the parallel axis theorem, show that the moment of inertia
of a rod about one end is 1/3 M L^2.
You beat me to it!
BTW I think "rotational" inertia is a much better term than
"moment of" inertia. I shall try to adopt it.
David
in the question.
Try this one:
um...
I = 1/12ML^2 + M(1/2L)^2
I = 1/12ML^2 + 1/4ML^2
I = 1/12ML^2 + 3/12ML^2
I = 4/12ML^2
I = 1/3ML^2
fortunately (or unfortunately), there weren't any questions about the parallel axis theorem on the test. i got a B+, not as good as i'd hoped, but considering how little i knew, maybe i should just be thankful. thanks for your help!
Tidy this up by collecting the terms for the rod and the particles.
Then check to see if your answer for the rod agrees with taking one rod
length 2d. mass 2M and applying the formula you have just derived
(immaculately) for a rod rotating about one end namely:
(1/3) (2M) (2d)^2
  • · Replies 28 ·
