Parallel Disk Capacitor E field
8 replies · 3K views
PhysKid45
Two 2.4-cm-diameter disks face each other, 1.9 mm apart. They are charged to ± 12 nC .
What is the electric field strength at the midpoint between the centers of the disks?
Q=12*10^-9
A= Pi * r^2 = pi*(.012)^2
Q/A= (12*10^-9)/(pi*(.012)^2)
E=(Q/A)/epsilon naught (8.85*10^-12)
E= 3*10^6
I am not sure where I go wrong, but I have one attempt left and keep getting the same answer
[Edit] answer: 2.7*10^6 but I would appreciate if someone could explain why
Q=12*10^-9
E= 3*10^6
Are you checking sig figs and units if entering online?
Hey student100, I am checking sig figs. It tells me to use 2
So you're entering 3.0?
Yup. I ended up guessing correctly, in an attempt to figure out the second part of the problem and the correct answer was 2.7*10^6 which I do not understand. Any ideas on how it would work out to be that?
Only thing that comes to mind is that they wanted you to use the percise formula for disks and not approximate them as infinite sheets of charge. Have you tried that?
There size compared to distance of separation leads me to be skeptical of that however. Are all the numbers presented correct?
Following Student100's advice, you should find that it does make a difference if you don't approximate the disks as infinite. However, I get 2.8 × 106 N/C rather than 2.7 × 106 N/C.
All numbers presented are correct.
I am not sure what you both mean by using the precise formula vs. approximating as an infinite sheet.
If you are taking a "calculus-based" physics course, then a standard example is the electric field of a circular disk.
http://www.phys.uri.edu/gerhard/PHY204/tsl36.pdf
