Parallel-plate capacitor with two dielectrics side by side
8 replies · 39K views · last reply
phyzmatix
[SOLVED] Parallel-plate capacitor: Two dielectric materials
A parallel-plate capacitor with area A = 5.56 cm^2 and separation d = 5.56 mm has the left half of the gap filled with material of dielectric constant K1 = 7.00 and the right half filled with material of dielectric constant K2 = 12.0. What is the capacitance?
[tex]C = \frac{\kappa \epsilon_{0} A}{d}[/tex]
[tex]\frac {1}{C_{tot}} = \frac {1}{C_{left}} + \frac {1}{C_{right}}[/tex]
Since it's one capacitor (two plates) and since the dielectric materials are next to each other (as opposed to stacked) I approached the problem as if the two halves of the capacitor were separate parallel capacitors and calculated:
[tex]C_{left} = 3.10 pF[/tex]
[tex]C_{right} = 5.31 pF[/tex]
[tex]C_{tot} = 1.96 pF[/tex]
But this is not amongst the given possible answers. Where did I go wrong?
Cheers
phyz
This is a serial connection of capacitors so you must add right and left halves capacity:
[tex]C=C_{right}+C_{left}[/tex]
Thanks for your reply...however, could you please explain why this setup acts as capacitors in series?
I apologize to bad equation [tex]C=C_{1}+C_{2}[/tex]
It's wrong... You have a good solution, because
[tex]V=\frac{q}{C}[/tex]
and [tex]V_{1}=\frac{q}{C_{1}}[/tex] [tex]V_{2}=\frac{q}{C_{2}}[/tex]
and [tex]V=V_{1}+V_{2}[/tex]
so [tex]\frac{1}{C}=\frac{1}{C_{1}}+\frac{1}{C_{2}}[/tex]
I appreciate your attempt at helping me Phizyk, but unfortunately we're no closer to understanding this problem than before...
Hi phyzmatix! :smile:
Thanks for the PM …
Did you divide by 2 instead of multiply?
Thanks for the PM …
Thanks for joining me here tiny-tim :smile:
Yes, I divided the total area given by 2 (I wish I had the means to show you the figure given with the question, on the figure they show that the left side is A/2 and the right side is also A/2)
So my understanding is that the left half of the parallel-plate capacitor has capacitance [tex]C_{left}[/tex] (calculated with K1 and A/2) and the right half has capacitance [tex]C_{right}[/tex] (calculated with K2 and A/2) but how to combine the two values into [tex]C_{tot}[/tex]?
(I'm not sure my assumption that the two can be treated as separate parallel capacitors is correct)
Well, they're side-by-side, not one-after-the-other, so they're "in parallel" rather than "in series" (plus, the question calls it a parallel-plate capacitor), so I think you just add them.
Isn't 8.41 one of the given answers?
(if not, what are the given answers? :wink:)
*DOH!*
I feel like such a tw@t :redface:
No wonder I didn't get the right answer, I was using the equation for capacitors in series...
*banging head against wall*
Cheers Tim! You legend! :biggrin:
(oh, by the by, 8.41 is indeed amongst the possibilities :wink:)
