Parallel Plates and charge density
The discussion focuses on calculating the total electric field at points A, B, C, and D due to three large square planes of charge with charge densities of -0.50 µC/m², +0.20 µC/m², and -0.30 µC/m². The electric field (E) is determined using the formula E = charge density / (2 * ε₀), where ε₀ is the permittivity of free space. The superposition principle is applied to sum the contributions of each plate, with attention to the direction of the electric field lines based on the charge sign. The final calculation for point B yields an electric field of -2.26e4 N/C.
  • Understanding of electric fields and charge density
  • Familiarity with the superposition principle in electrostatics
  • Knowledge of the formula E = charge density / (2 * ε₀)
  • Basic skills in vector addition for electric fields
  • Study the concept of electric field lines and their direction based on charge types
  • Learn about the superposition principle in electrostatics
  • Explore the effects of multiple charge distributions on electric fields
  • Investigate the role of permittivity of free space (ε₀) in electric field calculations
Students and professionals in physics, electrical engineering, and anyone interested in understanding electric fields generated by charged planes.
Fanman22
Three very large square planes of charge are arranged as shown (on edge) in Fig. 21-70. From left to right, the planes have charge densities per unit area of -0.50 µC/m2, +0.20 µC/m2, and -0.30 µC/m2. Find the total electric field (direction and magnitude) at the points A, B, C, and D. Assume the plates are much larger than the distance AD.
A | B | C | D
I know that the Efield= charge density/2epsilon but I'm having trouble adding the fields. For example, Point B I would think equals E of the first plate + E of the second plate (due to the positive and negative signs). My answer of 2.82e4 + 1.13e4 = 3.95e4...is this correct?
Thanks in advance for the help, it is greatly appreciated.
All plates contribute to the total field in all regions. You just need to give them the appropriate sign depending on which side of the plate you're on. Just remember the field lines of a plate point towards the plate if the charge is negative and away if it's positive.
ok, but would point B, for example, be influenced by the charge density on the 3rd plate? If so, I am assuming that i should draw the diagram with arrows and add up all arrows in one direction and subtract all arrows in the opposite direction.
Yes. Don't forget the superposition principle, that the total field is equal to the sum of the field contributions by all charges.
I'm not sure if I'm going about this correctly. Just for your reference, Plate 1 has a E of -2.82e4, Plate 2 an E of 1.13e4, and Plate 3 an E of -1.69e4...
Let's take point B:
I am considering fields to the left to be negative and to the right to be positive.
Plate 1 will be a negative 2.82e4
Plate 2 will be a negative 1.13e4
Plate 3 will be a positive 1.69e4
add those all up and the Efield that B experiences should be -2.26e4
Is that correct?
That looks right.
thanks, everything came out correct.
  • · Replies 18 ·
  • · Replies 58 ·
  • · Replies 26 ·
  • · Replies 16 ·
