I Parallel transport and entanglement
  • I
  • Thread starter Thread starter Heidi
Heidi
Hi Pfs,
When Bob and Alice receive maximally entangled particles, Bob can choose a direction and measure the spin along it.
If Alice does the same thing in the same direction she will get the same result. But what is "same direction" when space time is curved between them? Have we to use parallel transport of Bob's direction toward Alice?
Il looks like when you make a measurement on a particle, if nothing acts on the particle. repeating the same measurement
will give you the same result but if there is the action of an hamiltonian, doing the same measurement to get the same result is also something that evolves (with tim here)
No. In case the two particles were initially created in the singlet state (i.e. with total spin 0), then you could transport the direction along the trajectories of the particles. (But note that in this case, "If Alice does the same thing in the opposite direction she will get the same result".)
In general, you just have to "know" how the directions map to each other, because being maximally entangled does not yet fully specify the state. For example, if you have two particles in the singlet state, you can apply a unitary (2x2) matrix to one of the particles, and the state will remain maximally entangled. This unitary matrix gives you some mapping of directions.
Heidi said:
Hi Pfs,
I would assume the entangled state would act effectively as a gyroscope through curved spacetime. I wonder to what extent this has been tested?
Likes Heidi and topsquark
You'd have to use quantum field theory in the given background spacetime to see, what comes out. For sure it's highly non-trivial.
What do you think of the repeated measurement seen as entanglement (with timelike interval) ?
No, because any such transport in curved spacetime will not be unique.
The best approach I can see, theoretically, would be to Fermi-Walker transport (the more robust version of parallel transport that can handle non-geodesic curves) each of the measurement directions backwards along the worldlines of the two particles, to the event of their common creation, and then compare the directions. I think that is what a calculation using QFT in curved spacetime would end up amounting to. But that's just my intuitive guess; I have not actually tried to do the calculation (which, as @vanhees71 points out, would be highly non-trivial).
Likes Heidi, vanhees71 and gentzen
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
