Arc Length of Parametric Curve: t = 0 to t = 1
The discussion focuses on calculating the arc length of a parametric curve defined by the equations x = 4t² and y = 2t, over the interval from t = 0 to t = 1. The parametric arc length formula, integral from t = b to t = a of sqrt((dx/dt)² + (dy/dt)²)dt, is correctly identified. The user attempts to solve the integral using trigonometric substitution and integration by parts, but encounters errors in the integration process, particularly in the manipulation of terms involving secant and tangent functions. The final expression for the arc length is derived as (15/4)sqrt(68) - (14/4).
  • Understanding of parametric equations and their derivatives
  • Familiarity with integral calculus, specifically integration techniques
  • Knowledge of trigonometric identities and substitutions
  • Experience with integration by parts and partial fractions
  • Review the derivation of the parametric arc length formula
  • Practice trigonometric substitution techniques in integrals
  • Study integration by parts with a focus on secant and tangent functions
  • Explore the use of hyperbolic functions for integration simplification
Students studying calculus, particularly those focusing on parametric equations and arc length calculations, as well as educators seeking to clarify integration techniques.
sassafrasaxe
Find the arc length of a curve given parametrically from t = 0 to t = 1.
Curve given by x = 4t^2, y = 2t
[I think] parametric arclength =
integral from t = b to t = a of sqrt( (dx/dt)^2 + (dy/dt)^2)dt
dx/dt = 8t, and dy/dt = 2
Then I did S from 0 to 1 of sqrt((8t)^2) + (2)^2)dt
I then drew a triangle for trigonometric substitution, with the tangent case.
Let t = (1/4)tan(σ)
Let dt = (1/4)sec^2(σ) dσ
Let sqrt(64t^2 + 4) = 4sec(σ)
Then S[ sqrt( (8t)^2 + (2)^2) ]dt becomes
S of 4sec(σ) * (1/4)sec^2(σ) dσ
which equals S[ sec^3(σ) ] dσ
Now I solved that with integration by parts, letting u = sec(σ), and dv = sec^2(σ)
so that du = sec(σ)tan(σ)dσ and v = tan(σ)
now S[ sec^3(σ) ]dσ = sec(σ)tan(σ) - S[ tan^3(σ)sec(σ) ]dσ
that last little integral = S[ tan^3(σ)sec(σ) ]dσ = S[ ((sec^2(σ) - 1)*sec(σ)tan(σ)]dσ]
=(1/3)sec^3(σ) - sec(σ)
so the entire S[ sec^3(σ) ]dσ = sec(σ)tan(σ) - (1/3)sec^3(σ) + sec(σ)
so (4/3)S = sec(σ) + sec(σ)*tan(σ)
so S = (3/4)[sec(σ)tan(σ) + sec(σ)]
Now I'm replacing this value with the value given by my triangle for sec(σ) and tan(σ)
so that S = (3/4)[sqrt(64t^2 + 4)*4t + sqrt(64t^2 + 4)] evaluated from t = 0 to t = 1
which would be
(3)sqrt(68) + (3/4)sqrt(68)
minus
(6/4) + 2
(15/4)sqrt(68) - (14/4) as my final answer.
Could someone please tell me if I'm doing anything wrong? Maybe if I'm going about this entirely the wrong way? Unfortunately I don't even know the right answer, but even if I can't get the right answer, as long as I understand how to get there, I feel okay.
I would really appreciate it, and I'm sorry about the typing, I'm not very good at typing these problems out. So much thanks,
Sassy
Yes, that's correct.
Let t = (1/4)tan(σ)
Let dt = (1/4)sec^2(σ) dσ[/quote]
No big deal but I wouldn't use the word "let" here. You already said "let t= (1/4)tan(σ) and then dt= (1/4)sec^2(σ) follows from that.
Same point
How did you get this? with du= sec(\sigma)tan(\sigma)d\sigma)dxand v= tan(\sigma), as you say, that last integrand is sec(\sigma)tan^2(\sigma)d\sigma, not tan^3(\sigma)sec(\sigma)d\sigma.<br /> <br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> that last little integral = S[ tan^3(σ)sec(σ) ]dσ = S[ ((sec^2(σ) - 1)*sec(σ)tan(σ)]dσ]<br /> =(1/3)sec^3(σ) - sec(σ)<br /> so the entire S[ sec^3(σ) ]dσ = sec(σ)tan(σ) - (1/3)sec^3(σ) + sec(σ)<br /> so (4/3)S = sec(σ) + sec(σ)*tan(σ)<br /> so S = (3/4)[sec(σ)tan(σ) + sec(σ)] </div> </div> </blockquote> With tan^2(\sigma) sec(\sigma)d\sigma, I would proceed by putting everything in terms of sine and cosine:<br /> \int tan^2(\sigma) sec(\sigma)d\sigma= \int \frac{sin^2(\sigma)}{cos^2(\sigma)}\frac{1}{cos(\sigma)}d\sigma= \int \frac{sin^2(\sigma)}{cos^3(\sigma)}d\sigma<br /> <br /> With that odd power of cosine, I would multiply both numerator and denominator bycos(\sigma) to get
\int \frac{sin^2(\sigma)}{cos^4(\sigma)}cos(\sigma)d\sigma= \int\frac{sin^2(\sigma)}{(1- sin^2(\sigma))^2} cos(\sigma)d\sigma
and use the substitution u= sin(\sigma), du= cos(\sigma)d\sigma so that the integral becomes
\int \frac{u^2}{(1- u^2)^2}du
which would be
minus
(6/4) + 2
Sassy
Should this be 2sec(σ)?
Then also, let t = 1/4 sinh(σ) for a shorter solution, although this is an example of why I disliked integration, it is sometimes very arcane.
Okay great thank you very much. So I took it from where you left off, HallsofIvy, and I see what you mean that yes, I did mess up with the integral and it should have been tan^2(σ)sec(σ) d(σ).
Picking up where you left off, I suppose I would then need partial fractions?
Wow, this has been quite the problem! Looks deceivingly simple.
  • · Replies 22 ·
