Parametric Sweep Analysis in Comsol
To perform a parametric sweep analysis in COMSOL and store temperature values at a specific point, users can utilize the post-processing menu to create a point plot. For a parameter sweep, it is possible to save a zoomed range of values and visualize them on the same plot. In transient analysis, users can access the time-history post processor to add a variable for temperature at the desired node. This allows for plotting and listing temperature data against time effectively. Overall, these methods enable detailed analysis and visualization of specific temperature points during parametric sweeps.
yepyeni
Hi all;
I want to run a parametric Sweep analysis and I want to store the temperature value at just one point in the geometry. Is there anyone to know how to do that ?
Hi, if you are referring to a visualization problem, you can access to post-processing menu-cross section...-point plot and then plot a unique point.
Now I've a question, if I perform a parameter sweep (eg x=1:1:30), can I save a zoom (eg x=10:0.01:11) on the same file and then visualize the result on the same plot?
thanks to all
I'm not sure what you mean by parametric sweep analysis, but if you are doing a transient analysis, then just enter the time-history post processor (/POST26) and then add a variable. Click temperature and choose the node of interest. You can then plot and list the temp at that node vs time.
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
