Partial Derivative of a formula based on the height of a cylinder
The discussion focuses on calculating the partial derivative of a function in cylindrical coordinates, specifically using the variables (r, z, t) within the domain (0, H). It is established that the variable theta (θ) can be disregarded due to the symmetry of the problem around the z-axis, as both boundary and initial conditions are independent of θ. The recommended approach is to utilize a separation ansatz, as the conditions can be expressed as a product of r and z. Additionally, participants suggest using LaTeX features for improved readability of mathematical expressions.
  • Understanding of cylindrical coordinates in calculus
  • Familiarity with partial derivatives and Laplacian operators
  • Knowledge of boundary and initial conditions in differential equations
  • Experience with LaTeX for mathematical typesetting
  • Explore the application of the separation of variables technique in solving partial differential equations
  • Study the properties and applications of the Laplacian operator in cylindrical coordinates
  • Learn how to implement LaTeX in online forums for better mathematical expression
  • Investigate the implications of symmetry in physical problems, particularly in cylindrical systems
Mathematicians, physicists, and engineering students who are working with partial differential equations and cylindrical coordinate systems.
currently
Consider a cylinder of radius a and height H. The base of the cylinder is at z=0 and the top is at z=H. Find a function which satisfies ∂U/∂t = k(nabla)^2U in the domain and stated boundary conditions and initial conditions.
* ∂U/∂t = k∇^2U
* Boundary condition: U=0 on the surface of the cylinder at all times.
* Initial condition: U within the domain = α(r)β(z) at time t=0 where α(r)=e^-r
The function should use (r,z,t) variables
The domain is (0,H)
Since U is not dependent on angle, then theta can be ignored in the expression for Laplacian in cylindrical coordinates(?)
Yes, because also the boundary and initial conditions do not depend on ##\theta##, the problem is symmetric under rotations around the ##z##-axis. Then I'd try a separation ansatz since also the boundary and initial conditions separate into a product of ##r## and ##z##.
BTW: It would help very much, if you'd use the LaTeX features of the Forum software (MathJaX), because it makes the formulae much better readable:
https://www.physicsforums.com/help/latexhelp/
