Undergrad Why Does the Partial Derivative of a Sum Cancel Out?
The discussion centers on the cancellation of terms in the summation when taking the partial derivative with respect to a specific variable, denoted as x_i. Participants clarify that when differentiating the sum of squares, only the term corresponding to x_i contributes to the derivative, resulting in the expression 2x_i. The key takeaway is that all other terms yield zero due to the independence of the variables, confirming that the summation simplifies effectively during differentiation.
  • Understanding of partial derivatives in calculus
  • Familiarity with summation notation and its properties
  • Knowledge of independent variables in mathematical functions
  • Basic proficiency in algebraic manipulation
  • Study the properties of partial derivatives in multivariable calculus
  • Learn about the chain rule and its application in differentiation
  • Explore the concept of linearity in differentiation
  • Investigate the implications of variable independence in calculus
Students of mathematics, educators teaching calculus, and professionals in fields requiring advanced mathematical analysis will benefit from this discussion.
Ryan187
Why the summation of the following function will be canceled out when we take the partial derivative with respect to the x_i?
Notice that x_i is the sub of (i), which is the same lower limit of the summation! Can someone, please explain in details?
The ##x_i## are, I assume, independent variables. If ##i \ne j## then ##\frac{\partial x_j}{\partial x_i} = 0##.
Note that the answer should be ##2x_i##.
Thank you PeroK! Even if x_i is an independent variable. why the summation is canceled out? can you explain the derivative in detail, please? and you're right the answer is 2x_i not x_i
The summation is not needed because most terms in the sum are zero.
Likes Ryan187 and etotheipi
PS it might help is you use a different dummy variable for the definition of ##y##. Use ##j = 1## to ##n## instead of ##i##, for example.
@Ryan187 if you replace the free index ##i## with a concrete number, can you for instance evaluate$$\frac{\partial}{\partial x_3} \sum_{k=1}^5 ({x_k}^2)= \frac{\partial}{\partial x_3} ({x_1}^2 + {x_2}^2 + {x_3}^2 + {x_4}^2 + {x_5}^2)$$assuming the ##x_i## are independent variables?
Likes Ryan187 and Mark44
Ryan187 said:
explain
Differentiation is a linear function: ##\dfrac{\partial}{\partial x_j}(\alpha \cdot f(x)+\beta\cdot g(x))=\alpha\cdot \dfrac{\partial}{\partial x_j}f(x)+\beta\cdot \dfrac{\partial}{\partial x_j} g(x)##.
Here we only have a longer sum: ##x_1^2+x_2^2+\ldots+x_N^2##
This is the key -- expanding the sum, and then differentiating with respect to one of the terms in the sum.
So, in this case, I am kind of differentiating over one term that's why the sum will be canceled out?
Ryan187 said:
So, in this case, I am kind of dif\displaystyle{}ferentiating over one term that's why the sum will be canceled out?
No. You differentiate all terms. ##\displaystyle{\dfrac{\partial}{\partial x_i}\left(\sum_{j=1}^N x_j^2\right) = \sum_{j=1}^N \dfrac{\partial}{\partial x_i} (x_j^2)}##
I'll use my example again$$\begin{align*}\frac{\partial}{\partial x_3} \sum_{k=1}^5 ({x_k}^2)&= \frac{\partial}{\partial x_3} ({x_1}^2 + {x_2}^2 + {x_3}^2 + {x_4}^2 + {x_5}^2)\\ \\&= \frac{\partial}{\partial x_3}({x_1}^2) + \frac{\partial}{\partial x_3}({x_2}^2) + \frac{\partial}{\partial x_3}({x_3}^2)+ \frac{\partial}{\partial x_3}({x_4}^2)+\frac{\partial}{\partial x_3}({x_5}^2) \\ \\
&= 0 + 0 + \frac{\partial}{\partial x_3}({x_3}^2) + 0 + 0\end{align*}$$I see I've been beaten to it by @fresh_42 :wink:
Likes Ryan187
I have these shortcuts on the keyboard:
\displaystyle{}
\dfrac{}{}
\left(\right)
\partial
:smile:
  • Wow
Likes jim mcnamara and etotheipi
but in this case, we derive with respect to x3 (i=3) which is one term, but the original derivative is with respect to (x_i) which is the whole i's values?!
No. ## i ## is just one specific index, an arbitrary one, but a specific one. That's why we have to distinguish this index from the summation index which runs over all. One of them matches ##j=i## whereas all others do not: ##j\neq i##. The former yields ##2x_i##, the latter yields the zeros.
Likes Ryan187
Got it now! Thanks, guys, you're amazing! It is my first thread to this community!
Likes etotheipi
  • · Replies 16 ·
