Graduate Partial derivative of composition
The discussion centers on the calculation of the partial derivative of a function \( C(x, y) \) where \( y \) is a function of \( x \). Participants clarify that the expression \( \nabla_x C(x_0, y(x_0)) \) represents the partial derivative of \( C \) with respect to \( x \) while substituting \( y(x_0) \) for \( y \) and \( x_0 \) for \( x \). They emphasize the importance of distinguishing between the functions \( g(x) = C(x, y(x)) \) and \( h(x) = \nabla C(x, y(x)) \), noting that the interpretation of the gradient depends on the context of the variables involved.
  • Understanding of partial derivatives and gradients in multivariable calculus
  • Familiarity with the notation of functions and their derivatives
  • Knowledge of vector calculus, particularly in the context of functions of multiple variables
  • Concept of function composition and its implications in differentiation
  • Study the chain rule in the context of multivariable calculus
  • Learn about the implications of function composition on differentiation
  • Explore vector calculus concepts, specifically the gradient and its applications
  • Investigate the differences between scalar and vector fields in calculus
Mathematicians, physics students, and anyone involved in advanced calculus or differential equations who seeks to deepen their understanding of partial derivatives and their applications in multivariable functions.
SchroedingersLion
Hi guys,
suppose we have a function ##C(x, y)## into the real numbers. Suppose also that ##y=y(x)##, i.e. ##y## is a function of ##x##.
Now in my script, I have a term ##\nabla_x C(x_0, y(x_0)) ##. From my point of view, this means that you take the partial derivative of ##C(x,y)## with respect to x and then insert ##y(x_0)## for ##y##, and ##x_0## for ##x##.
I would not consider the x-derivative of ##y(x)##, since then the subscript at the nabla operator wouldn't make any sense as this would simply be ##\nabla C(x_0, y(x_0))##.
Is this line of thinking correct?
Best
SL.
Mathematics news on Phys.org
I agree.
I would interpret the last expression as vector with the two partial derivatives as components.
Likes SchroedingersLion
Hi guys,
In this case you must be careful about what function you are talking about and how you are differentiating. Technically, you have now defined a new function of a single variable:
$$g(x) = C(x, y(x))$$
And, the derivative of ##g## is given by:
$$g'(x) = \frac{\partial C}{\partial x}+ \frac{\partial C}{\partial y}y'(x)$$
It would make no sense, of course, to take the gradient of ##g##. And:
$$g'(x_0) = \frac{\partial C}{\partial x}(x_0, y(x_0)) + \frac{\partial C}{\partial y}(x_0, y(x_0))y'(x_0)$$
However, you have another function which is the gradient of ##C##:
$$\nabla C = \frac{\partial C}{\partial x} \hat x + \frac{\partial C}{\partial y} \hat y$$
Note that this function is also a function of two variables. And, you can now define another function by:
$$h(x) = \nabla C(x, y(x)) = \frac{\partial C}{\partial x}(x, y(x)) \hat x + \frac{\partial C}{\partial y}(x, y(x)) \hat y$$
And, of course:
$$h(x_0) = \nabla C(x_0, y(x_0)) = \frac{\partial C}{\partial x}(x_0, y(x_0)) \hat x + \frac{\partial C}{\partial y}(x_0, y(x_0)) \hat y$$
In the context of your question, therefore, you need to decide which function you are dealing with: ##g## or ##h##.
Thanks for the responses!
The two of you seem to disagree about my own interpretation what to do.
@PeroK
I should have noted that ##x## and ##y## are each in ##R^d## so the partial derivatives should be gradients.
From your explanations, I still don't see what the subscript then means in ##\nabla_x##. If ##C(x, y(x))## implies the redefinition of ##C(x,y)## as a function ##g(x)##, then the subscript of the gradient would be useless, right?
Therefore, my original idea:
@PeroK
Okay, so you actually have a function of two vector variables: ##C(\vec x, \vec y) = C(x_1, x_2, x_3, y_1, y_2, y_3)##.
There's the same issue. Are you first reducing ##C## to a function of a single vector ##\vec x##, using ##\vec y = \vec y(\vec x)##? Or, are you taking the gradient of ##C## with respect to ##\vec x## and then plugging in ##\vec x_0, \vec y_0##?
Which one of these it is depends on the context of what you are doing.
That's essentially what I don't know. I had hoped there was some clear convention =(
I don't think it's a matter of convention. It's a matter of the author being unambiguous. You should be able to work out which one it is from what follows.
  • · Replies 22 ·
