Partial fraction decomposition of x²/(1-x⁴)²
39 replies · 8K views
Nyasha
Find the partial fraction decomposition of :
[tex]\frac{x^2}{(1-x^4)^2}[/tex]
[tex]\frac{x^2}{(1-x^4)^2}=\frac{A}{(1-x^4)}+\frac {B}{(1-x^4)^2}[/tex]
[tex]=A(1-x^4)+B[/tex]
when x=1
[tex]1=A(1-1^4)+B[/tex]
Hence B=1 and A=0
[tex]\frac{x^2}{(1-x^4)^2}=\frac{0}{(1-x^4)}+ \frac{1}{(1-x^4)^2}[/tex]
How come according to the answers at the back of the book l am wrong. Where have l done a mistake ?
When x = 1, you have
[itex]1 = A(1-1^{4})+B = A(0)+B = B[/itex]
So B = 1 works, but what values of A satisfy that equation? What values don't? If there are multiple values A can have, then you need to determine which is the correct one.
Well, 0/(1-x^4)^2+1/(1-x^4)^2 clearly does not equal x^2/(1-x^4)^2, now does it? You should probably factor the denominator completely and then look up what partial fractions look like if you have a quadratic in the denominator.
Dick said:
Well, 0/(1-x^4)+1/(1-x^4)^2 clearly does not equal x^2/(1-x^4)^2, now does it? You should probably factor the denominator completely and then look up what partial fractions look like if you have a quadratic in the denominator.
Isn't the denominator already in a factored form ? Should l expand it ?
The denominator is a reducible quartic...I'll give you a hint to factoring it: [itex](1-x^a)(1+x^a)=[/itex]____?
[tex](1-x^4)(1-x^4)=(1-x^2)^2 (1-x^2)^2[/tex]
No, I meant [itex]1-x^4[/itex] is a reducible quartic...factor that:smile:
I am getting very confused. Show me an example which has nothing to do with this question maybe l will understand what you are trying to say
I'm not sure how much simpler I can make it...do you really not know how to factor [itex]1-x^4[/itex]? It is something you should have been taught in high school...
"Reducible quartic" send me a little bit off track:smile:
[tex]1-x^4=(1-x^2)(1+x^2)=(1+x)(1-x)(1+x^2)[/tex]
Will this mean l will be left with :
[tex]\frac{x^2}{(1-x^4)^2}=\frac{A}{(1+x)}+\frac {B}{(1-x)}+\frac{Cx+D}{1+x^2}[/tex]
Yes!:smile:
Careful:
[tex]\frac{x^2}{(1-x^4)^2}=\frac{x^2}{(1+x)^2(1-x)^2(1+x^2)^2}[/tex]
gabbagabbahey said:
Yes!:smile:
Careful:
Uhhmmm, which means
[tex]\frac{x^2}{(1-x^4)^2}=\frac {x^2}{(1+x)^2(1-x)^2(1+x^2)^2}=\frac{A}{(1+x)}+\frac{B}{(1-x)}+\frac{C}{1-x}+\frac{D}{1-x}+\frac{Ex+F}{1+x^2)}^2[/tex]
Nyasha said:
Uhhmmm, which means
Your LaTeX is a little a sloppy; surely you mean:
[tex]\frac{x^2}{(1-x^4)^2}=\frac {x^2}{(1+x)^2(1-x)^2(1+x^2)^2}=\frac{A}{(1+x)}+\frac{B}{(1+x)^2}+\frac{C}{(1-x)}+\frac{D}{(1-x)^2}+\frac{Ex+F}{(1+x^2)}+\frac{Gx+H}{(1+x^2)^2}[/tex]
right?
right?
Yes that what l mean, is it correct ?
gabbagabbahey said:
Yes, now determine the constants...
[tex]x^2=A(1-x)^2(1+x)+B(1-x)^2+C(1-x)(1+x)^2+D(1+x^2)^2+(Ex+F)(1-x)^2+(Gx+H)(1-x)^2[/tex]
when x=1
[tex]1= A(1-1)^2(1+1)+ B(1-1)^2+C(1-1)(1+1)^2+D(1+1)^2+(Ex+F)(1-1)^2+(Gx+H)(1-1)^2[/tex]
[tex]4D=1[/tex]
[tex]D=\frac{1}{4}[/tex]
when x=-1
[tex]1=A(1+1)^2(1-1)+B(1+1)^2+C(1+1)(1-1)^2+\frac{1}{4}(1+1)^2+(Ex+F)(1+1)^2+(Gx+H)(1--1)^2[/tex]when x=o
0=A+B+C+\frac{1}{4}+(Ex+F)+ (Gx+H)
It got so many unknowns and only three equations, how do l get around this last hurdle
Compare coefficients.
That doesn't look right at all, be careful with your multiplication!
There is an easier way than solving the system of equation this method results in.
Try plugging in x=i and x=-i for starters
Does this look correct:
[tex]A(1+x)(1-x)^2(1+x^2)^2+B(1-x)^2(1+x^2)^2+C(1-x)(1+x^2)^2(1+x)^2+D(1+x^2)^2(1+x)^2+(Ex+F)(1+x)^2(1+x^2)(1-x)^2+(Gx+H)(1-x)^2(1+x)^2[/tex]
That's better!:smile:
Now start plugging in points...I recommend using 1,-1,0,i,-i,2,-2 and 3
Gabbagabbahey thanks for your help but l can't think l can continue for today it is already 4:00am. First thing when l wake up tomorrow l will try to solve it using these points and then show you the solution when l get it. Again thanks very much for your help
gabbagabbahey said:
You're welcome!:smile:...get a good night's sleep!:zzz:
When x=1
[tex]D=\frac{1}{16}[/tex]
when x=-1
[tex]B=\frac{1}{16}[/tex]
when x=0
[tex]0=A+\frac{1}{16}+C+\frac{1}{16}+F+H[/tex]
The calculus textbook says l should solve for the coefficients by method of equating them. So my question is should l expand this [tex](1+x)(1-x)^2(1+x^2)^2[/tex] and then equate the coefficients ? I was wondering if there is an easier way to equate the coefficients without going through all this algebra
Nyasha said:
When x=1
when x=-1
when x=0
Check your math again...
Did l do something wrong for when x=0 ? I would also like to know if l must expand [tex] (1+x)(1-x)^2(1+x^2)^2[/tex] before equating the coefficients ?
gabbagabbahey said:
I get B=D=1/8...
When x=-1
[tex]B(1-x)^2(1+x^2)^2=x^2[/tex]
[tex]B(1--1)^2(1+(-1)^2)^2=(-1)^2[/tex]
[tex]B=\frac{1}{(1--1)^2(1+(-1)^2)^2)}=\frac{1}{16}[/tex]
I can't find where l made the mistake ?
You didn't make a mistake...i did... 2^4=16 not 8 :redface:
Anyways... you can either expand everything out and compare coefficients, or continue plugging in points...x=i and x=-i make finding G and H very easy...
Man, thanks very much for your help. I really appreciate the time you spend with me on this question.
