Particle accelerating in one direction with initial velocity in another
12 replies · 6K views · last reply
XPX1
A particle passes through the origin with an initial speed of 5.6 m/s in the positive y direction. The particle accelerates in the negative x direction at 5.2 m/s2.
(a) What are its x and y positions after 4.0 s?
m (x position)
m (y position)
(b) What are vx and vy at this time?
m/s (vx)
m/s (vy)
This question seems pretty hard to me, I have tried about 4 times to get the answer to no avail, here's what I have done.
To try and find out where its x and y positions were after 4.0 seconds, I plugged it into the Position Versus Time Equation, xf=xi+vixt+.5axt^2
Since I have the givens
time = 4.0
Vi=5.6
a=-5.2^2
I plug it into the equation.
xf=xi+vixt+.5axt^2
xf=0+5.6(4)+.5(-5.2)^2(4.0)^2
xf=238.72
however, this answer for part A. was not correct.
Can anyone tell me what I am doing wrong here?
You have to treat each direction separately.
you will have two equations
eq 1: xf=xi+vixt+.5axt^2
eq 2: yf=yi+viyt+.5ayt^2
think about what the question says and in which direction each velocity and acceleration is in.
Aaahh.. I see, so if it is going in the x direction at -5.2m/s^2 then after 4 seconds, it would be xf=0+0+.5(-5.2)^2(4)^2?
and if it is going in the y direction
yf=0+5.6(4)+.5(?)(4)^2
So, how do I figure out the y if I am not given the acceleration?
If you're not given an acceleration, I think you can assume that there is none and the particle is moving at a constant velocity in the y direction.
I got the final position of the y correct, but for x I am still lost.
if X is accelerating at -5.2m/s^2, where will it be in 4 seconds?
I plugged it into the position versus time equation
xf=216.32
The above answer was false, I am completely lost on this, thanks for your help on solving the y position though conquer!
xf=xi +vixt +.5a(t^2)
compare that to your equation
"xf=0+0+.5(-5.2)^2(4)^2"
you have something I don't...
what am I missing? I still don't see what I have that you dont
heh, take a look at the acceleration...after everythign cancels, you have
xf=.5(a^2)(t^2)
I have
xf=.5(a)(t^2)
But.. its 5.2 meters a second squared, so doesn't that make it 5.2^2? or do I take the square root of 5.2 and put it into a?
xf=.5(-5.2^2)(4^2)
or...
xf=.5(2.28)(4^2)?
okay, here's the units:
acceleration = m/s^2
t^2 = s^2
so
a x t^2 = m/s^2 x s^2 = m
so it's just xf = .5(-5.2)(4^2), this will give you your answer in meters.
a is already in m/s^2, if you square it again, your units would be m^2/s^4
Ah thanks, that was correct! I still don't quite understand why you don't leave it m/s^2 though
hmm... I'm not sure what you mean by this.
You ARE leaving the acceleration in m/s^2 because by definition, acceleration is in m/s^2. Doing anything to that acceleration would change the formula.
You don't want the final answer in m/s^2 because you have a distance, x, which should be in meters, on the other side of the equation.
maybe there's someone else in the forums who can explain this more clearly... anybody care to give it a try?
