What is the solution for particle motion between two masses?
The discussion focuses on deriving the equations of motion for a test particle influenced by two masses, m1 and m2, separated by a distance R. The initial attempt to solve the problem involved integrating the potential energy equation, but it was pointed out that the correct approach requires expressing acceleration in terms of velocity and position. The participants clarified that the test particle's motion should be analyzed without assuming equilibrium, as even slight deviations would lead to instability. The final form of the motion equation is established as a second-order differential equation, which can be solved using energy conservation principles. The conversation emphasizes the importance of correctly applying Newton's laws and integrating appropriately to find the particle's motion.
Gregorski
Statement of the problem (quoting from my assignment):
a) write equations of motion
b) try to solve analytically
Given: m1, m2 - two masses
R - distance between two masses
V=-G(m1/r + m2/(R-r))
F=-dV/dr
a) Equations of motion: v = dr/dt, a=dv/dt
b) Solution
dV/dt = G(m1/r2 - m2/(R-r)2)
Separating variables
dV=Gm1*1/r2dr+Gm2*1/(R-r)2dr
Integrating both sides I basically get what I started with
V=-G(m1/r +m2/(R-r))+C
So, I know what I am doing is not right. I know that somehow the equations of motions need to come into play, but don't understand the relation. My system is in equilibrium, so both velocity and acceleration are equal to 0.
I am not a physics student (I am in Math), but I'm working on a little summer project in Physics.
Then you don't have to solve any differential equations. Just set the acceleration to zero and solve for r.
That doesn't seem to agree with your problem statement, however. Solving the equations of motion for the equilibrium point only is trivial.
V=-G(m1/r - m2/(R-r))
F=-dV/dr
b) Solution
dV=Gm1*1/r2dr-Gm2*1/(R-r)2dr
V=-G(m1/r - m2/(R-r))+C
(1) I don't see anywhere in the problem statement the stipulation that your system is in equilibrium. In fact, it specifically asks for equations of motion.
(2) The derivative ##dV/dt## has no relevance in this problem; the derivative ##dV/dr## is what matters here.
(3) The concept of "equilibrium" is suspect in this case. If you happen to be at the equilibrium point and with zero velocity, then even the tiniest fluctuation to one side or the other will put you into a location that will cause the particle to crash into either ##0## or ##R##. So, even if you were not quite at equilibrium, but were off a by a bit in the 200th decimal place, your system would move away and eventually crash.
Ray,mfb,
Thanks for the input. I changed the equation for potential. And well, yes you both are probably right, let's assume that the system is not in equilibrium. Then the equations of motion would be
F1 = m1d2r/dt2 and F2=m2d2(R-r)/dt2 ?
It's not clear to me what the situation is. Are you asked to write the equation of motion for an object between the two masses, which is what the potential in your original post suggests, or are you being asked to write the equations of motion for the two masses, which is what your last post suggests?
Well, yes it wasn't clear to me either. But, I think now it is. So, I need the equation of motion for the test particle, and I hope it will look like this
$$F=m_0\ddot r (t),$$
where ##m_0## is the mass of the test particle.
Then the differential equation will be
$$m_0\ddot r=-G \frac {m_1} {r^2} + G\frac {m_2} {(R-r)^2}$$
The only thing I am not sure is the signs. And also how to solve it. It's separable and I probably need to reduce the order by some smart substitution. But, Ray, you mentioned that the equation can be simplified by using the fact that the system's energy is conserved. How would you go about it?
The righthand side is missing a factor of ##m_0##.
You seem to be assuming that the test particle lies directly between the two masses. Was this your intent?
Vela,
I am not sure what you mean by the right hand side missing a factor of ##m_0##. Yes, the particle lies between the two masses.
What's Newton's law of gravity?
Aha! So, ##m_0##'s cancel, and we have:
$$\ddot r=-G \frac {m_1} {r^2} + G\frac {m_2} {(R-r)^2}$$
I hope, this time it's correct.
Yes, but that is what you had already in the line following
Gregorski said:
b) Solution
Where you went wrong is here:
You integrated the left hand side wrt t but the right hand side wrt r. That is invalid.
As Ray hinted in post #3, you need to express the acceleration in terms of dv/dr. This is a standard trick which you've probably encountered.
Thanks haruspex,
So, we have:
$$\frac {dv} {dt} = -G\frac {M_1} {r^2} + G\frac {M_2} {(R-r)^2}$$
And using the standard trick:
$$v\frac {dv} {dr} = -G\frac {M_1} {r^2} + G\frac {M_2} {(R-r)^2}$$
Now, separate the variables and integrate:
$$\int v \,dv=-\int G \frac {M_1} {(R-r)^2}\,dr + \int G \frac {M_2} {r^2}\,dr$$
$$v^2=-2G\frac {M_1} {(R-r)} + 2G \frac {M_2} {r}$$
$$\frac {dr} {dt}=\pm\sqrt {-2G\frac {M_1} {(R-r)} + 2G \frac {M_2} {r}}$$
What do I do now? I guess, I could separate the variables again, but integrating it is not going to be easy. Any hints appreciated. By the way, I'd like to thank everybody chipping in, it's been fun working this out, so far.
Gregorski said:
Thanks haruspex,
So, we have:
Right. And you might notice the first integration gives you the energy equation but with mass canceled out.
  • · Replies 16 ·
  • · Replies 19 ·
  • · Replies 42 ·
