Particle falling in earth's gravity with air resistance.
A particle falling under Earth's gravity experiences a force of air resistance defined as F = −αv², where α is a constant. The terminal speed is given as 20.2 m/s, and the mass of the particle is 2.6 kg. To determine the constant α, one approach involves solving the differential equation related to the forces acting on the particle. Alternatively, a simpler method is to analyze the force balance when the particle reaches terminal velocity, where the net force equals zero. Understanding both methods can enhance problem-solving skills in physics.
kraigandrews
A particle falls in Earth's gravity. The force of air resistance is F = −αv v where v is the velocity, v is the speed, and α is a constant. (The direction of the force is opposite to the velocity, and the magnitude of the force is αv2.) If the terminal speed is 20.2 m/s and the mass is 2.6 kg, determine the constant α.
F=ma=mdv/dt
I was hoping somebody could point me in the right direction. I know how to solve a problem with just a resistive force, however, I am not sure where to start when given both the speed and velocity vector in the retarding force. So just any guidance as to where to start would be greatly appreciated.
Thanks.
You could solve this by solving the differential equation that way you'll get the x(t) function, and from there you can calculate the constant
or, you could think about the force balance after some time when particle reaches it's final speed
Start with F = ma. What are the expressions for the individual forces that act on the particle? What is the net force F that acts on the particle?
Ok, so how would I incorporate the vector v and the speed v into the diff eq?
you can divide it into components, and then solve the differential equation for each component, that's harder way than just writing the net force balance for the time when speed reaches it's final speed, but you'll learn more from it;)
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 39 ·
