How Does Particle in a Box Relate to Quantum Mechanics?
  • Thread starter Thread starter Zeynaz
    Box Particle
The discussion centers on understanding the particle in a box model in quantum mechanics, specifically how potential and kinetic energy relate to a particle's behavior. The original poster struggles with calculations involving energy and velocity, mistakenly using the mass of an electron instead of the mass of a ball. Clarifications reveal that inside the box, potential energy is zero, meaning total energy equals kinetic energy. The conversation emphasizes the importance of correctly applying formulas and understanding the assumptions of the model, particularly the concept of infinite potential outside the box. Accurate calculations and a grasp of these principles are essential for solving related problems effectively.
Zeynaz
A ball of mass 3 g is trapped in a box with infinitely high walls. The width of the box is 8 cm.
a) Calculate the speed of the ball when it is in the ground state of the box
b)Estimate the quantum number n if the ball is moving with a constant speed of 2 m/s in the box
Ek= 1/2 (m)(v)^2
E=hf
E-n= (n^2*h^2)/ (8*m*L^2)
I am having difficulties understanding this concept. Particle in a box (as far as i understood) shows that the electrons or particles need a certain about of potential energy to escape the one-dimentional potential well. I think its pretty similar to the concept of the electons and ionising energies. (correct me if i am wrong).
so in question a) i tried to use the formula by just using the values i knew, L=0.08 m and m=3e-3 kg. I also took n=1.
As a result E=4.32e-30 J. When i equate this energy with KE. I get a small velocity of 3m/s. (The correct answer is 1.0e-30 m/s)
I am not sure how to find the right answer.
Also, because the ball is in a box with infinitely high walls, it should have an infinite potential energy thus inifinite KE. So how is it possible to find a value for this.
can someone explain/help?
thanks!
It's difficult to see how such a tiny energy could equate to ##3 m/s## for an object of ##3g##.
The potential is 0 inside the box.
oh right i used m as the electron but i had to use the mass of the ball.
this gives me v= 5.37e-14 m/s which is still not the correct answer.
Also, if the potential is 0 inside the box, E=KE.
You need to show your calculations. Although it looks like you've simply not squared Planck's constant.
yes you were right i made a mistake with my calculations.
then in this case my only question would be;
would it be possible to say that E(n)= PE+KE= hf?
Thers is no potential in the box. That's a basic assumption about the problem. The only potential is the "infinite" potential outside the box, which stops the particle getting out.
alright, thanks!
  • · Replies 30 ·
  • · Replies 18 ·
