Particle in a triangular potential well
masterjoda
Particle is in a potential well in the shape of a isosceles right-angled triangle. Need to find the wave function and allowed energies.
How to determinate a boundaries for the potential when that line is in a form of some linear function, there is no strict point between potential equal to zero and infinity potential.
I tried potential as kx for 0<x<\frac{a}{2}, and -kx for \frac{a}{2}<x<a, but seems that is not right.
Plot your potential function. Is it a well? Write up a potential function which has minimum at x=0. ehild
This plot of potential function
Your function is not the same as the plot. -kx is negative in the range a/2<x<a
By the way, the drawing shows a hill instead of a well.
ehild
Storry, like this
That is better. What is the potential function?
ehild
That is my main problem, I don't know how to write it, I know that potential is zero inside and ∞ outside, that green area is unreachable for the particle.
You know the equation of a straight line? You have a straight line for 0<x<a/2 which intersects the x-axis at x=a/2, and makes -45° angle with it. And you have an other equation for a/2<x<a, that encloses a positive angle of 45° with the x axis.
ehild
What is this supposed to mean?
The potential isn't zero inside. It varies with x.
If you want to make things a bit simpler, take ehild's suggestion to center the well at x=0.
Yes, exactly.
If I center the well at x=0 then I have a function
V(x)=<br /> \begin{cases}<br /> -x &amp; \text{for } -\frac{a}{2}&lt;x &lt; 0 \\<br /> x &amp; \text{for } 0 &lt; x &lt; \frac{a}{2} \\<br /> 0 &amp; \text{for } x=0\\<br /> \infty &amp; \text{elsewhere}<br /> \end{cases}
Looks good. Now what?
I need to find ψ and allowed energies inside the well.
Well, we're not here to do your homework for you. Show us your work. What do you have so far?
I've just realized that the right potential is V(x)=\left | x \right | \text{for } x\in \left \{ -\infty, \infty \right \}
So far I have this:
-\frac{\hbar^2}{2m}\frac{\mathrm{d^2}\psi }{\mathrm{d} x^2} + |x|\psi=E\psi
c=\frac{2m}{\hbar^2} and k=\frac{\sqrt{2mE}}{k}
solution is \psi(x)=C_1\text{Ai}(\frac{cx-k^2}{c^{\frac{2}{3}}})+C_2\text{Bi}(\frac{cx-k^2}{c^{\frac{2}{3}}}) because x is always > 0, Bi goes to ∞ so C_2 have to be 0. And final solution is \psi(x)=C_1\text{Ai}((\frac{2m}{\hbar^2})^{\frac{1}{3}}(x-E)). I've determined the energy from conditions \psi^{(1)}_n=\psi^{(2)}_n and \psi&#039;^{(1)}_n=\psi&#039;^{(2)}_n. And energies are: for even E_n=-a&#039;_{n+1} and for the odd E_n=-a_{n+1}. Normalization is a bit tricky C_1^2\int_{-\infty}^{\infty} \text{Ai}^2(x-E_n)dx=1, I don't know how to solve this integral.
Your solutions don't work out unit-wise. For example, you can't subtract E from x. They don't have the same units.
Yes they do, potential at x have the same value as the x coordinate, V(x)=|x|, unit of that x is the same as the unit of E.
