Schmetterling
- Messages
- 31
- Reaction score
- 0
Hello,
I would like you to check this problem.
A particle of mass m is moving in a potential V(x) = [itex]\frac{cx}{x^2+a^2}[/itex], where a, c > 0.
1. Plot V(x)
2. Find the position of stable equilibrium and the period (small oscillations)
3. Find the values of velocity for which the particle: (a) oscillates, (b) escapes to [itex]\infty[/itex], (c) escapes to [itex]-\infty[/itex].
V(x) = [itex]\frac{cx}{x^2+a^2}[/itex], a, c > 0.
1. Well, I started by doing x = 0 to find the value of V in the origin.
Next, x = a --> V(x) = [itex]\frac{c}{2a}[/itex], x = na (n>1) --> V(x) = [itex]\frac{nc}{a(n^2+1)}[/itex]. With c = 1 I can plot V(x) for x = a/2, a, 2a, 3a.
But if I do x = -na, V(x) turns negative... I think V(x) should be positive along the entire x-axis, shouldn't it? Otherwise, how can the particle oscillate?
2. I suppose the position of stable equilibrium is x = 0, isn't it?
Period = ?
3. Velocity. In order to the particle doesn't go to infinity (i.e. it stays in the region -a[itex]\leq[/itex] x [itex]\leq[/itex] a), its kinetic energy K needs to be [itex]\leq[/itex] V, right? Then, with K = [itex]\frac{mv^2}{2}[/itex] = V(x=a), (the maximum value of) v = [itex]\sqrt{ \frac{2V}{m} }= \frac{1}{\sqrt {ma}}[/itex] . For v > [itex]\frac{1} {\sqrt{ma}}[/itex] the particle escapes to infinity. But, what happens when x is negative?
Thank you.
1. Plot V(x)
Period = ?
Thank you.
