Particle's Equation, Velocity and Acceleration
4 replies · 3K views
defaultusername
r(t) is the position of a particle in the xy-plane at time t. Find an equation in x and y whose graph is the path of the particle. Then find the particle’s velocity and acceleration vectors at the given value of t.
First derivative = velocity
(velocity=distance/time)
Second derivative = acceleration
(acceleration=velocity/time)
To find the Equation, I first organize it into a set:
[ et, 2/9 e2t ]
Then I just plug in the value of t (ln3)
[ eln3, 2/9 e2(ln3) ]
I then reconstruct the original problem with the new values:
r(t) = eln3 i + 2/9 e2(ln3) j
r(ln3) = e1.0986 i + 2/9 e2.1972 j
then I change the i / j to x/y
r(ln3) = e1.0986 x + 2/9 e2.1972 y
As for velocity and acceleration, so far I have figured it like this:
Velocity:
[ et, 2/9 e2t ]
[ te, 4/9 et ]
Velocity = tei + 4/9etj
Acceleration:
[ e, 4/9 te]
Acceleration = tei + 4/9 tej
Am I taking the derivative correctly? As far as I know, e remains as e, even after the derivative, right?
thanks in advance
[ et, 2/9 e2t ]
Velocity:
[ et, 2/9 e2t ]
[ te, 4/9 et ]
Acceleration:
[ e, 4/9 te]
thanks in advance
For the derivatives of et, you should review the rules of differentiation for such functions and not neglect application of the chain rule.
http://www.themathpage.com/acalc/exponential.htm
Remember, et is not differentiated like xn.
You have not done the second part, which says "Find an equation in x and y whose graph is the path of the particle". This means that instead of representing the particle's orbit as ##(x(t),y(t))## you should represent the curve of the orbit (not including "time" information) as an equation of the form ##y = F(x)## or ##x = G(y)## or ##H(x,y) = 0##, and you are to figure out the functions ##F## or ##G## or ##H##, as needed.
