Particle's path in magnetic field
The discussion focuses on calculating the path of a charged particle in a magnetic field, specifically using the Lorentz Force equation. The charge is given as 3C, velocity as 10 m/s, and magnetic field strength as 4T. The relevant equations for determining the radius (R = mv/qB) and period (T = 2πR/v) of the particle's motion are highlighted, but the mass of the particle remains unspecified, leading to confusion. Participants emphasize that mass is independent of charge, and the challenge lies in solving for both mass and radius simultaneously without additional information.
  • Understanding of the Lorentz Force equation (F = q(E + v x B))
  • Knowledge of circular motion principles in physics
  • Familiarity with the concepts of charge, mass, and their relationship in electromagnetic contexts
  • Basic proficiency in algebra for solving equations with multiple variables
  • Research the derivation and applications of the Lorentz Force equation in electromagnetic fields
  • Study the relationship between charge and mass in particle physics
  • Learn about the implications of varying mass in charged particle motion within magnetic fields
  • Explore practical experiments that demonstrate the principles of charged particles in magnetic fields
Students studying electromagnetism, physics educators, and anyone interested in the dynamics of charged particles in magnetic fields.
ivanwho49
A charge enters a magnetic field. Draw the path the charge will follow and find the radius and period of the particle's path.
v=10m/s (drawn as a straight line pointing right)
q=3c
B=4T (points outward)
I'm not sure.
The charge is drawn as positive. Wouldn't I need the mass for an equation? I don't know what the mass would be. Would it just be the mass of a proton?
Also, anyone know what equation I would use?
I think the equation for radius is mv/(qB) but I still don't know if I should use 1.67*10^(-27) kg as the mass. Q = 3C so it seems like it would be a mistake to make the mass equal to that of a proton's mass when Q does not equal 1.6*10^(19) C...
Then the equation for the period is qB/m..?
q=3c
I'm not sure.
Welcome to the PF.
The Relevant Equation would be the Lorentz Force equation. Can you show us what that is?
And I think you are right -- the Lorentz force just gives the force -- you need the mass to know what the radius of the resulting circular motion is. Have you written out the full question?
Ivan, your equation seems correct. As for the mass can you think of a reason why an object the size of a house could also have the charge given in the question? The mass might be able to be obtained from the equation you used to derive r=mv/qb. What equation was this?
Welcome to the PF.
The Lorentz Force equation is F = q(E + v x B) but I don't know how to use it in this occasion.. I have the question written out exactly as our professor stated it but I'm assuming the mass should be stated because I don't know how to solve it otherwise.
So mass is independent of charge...? but I thought a single proton would always have charge +e. So in this case, the charge is 3C.. is it possible that it still has the same mass as a regular proton?
The equation used to derive r=mv/qb is F=qvB=m(v^2/R).
I can find out what the force is with Lorentz Force equation as berkeman said, I know what q, v, and B are, but that still leaves m and R. It seems to me as if both quantities are dependent of each other and I must know one to get the other. Is there a way around this?
Thank you both!
Your F = q(E + v x B) is spot on. There is only a B field, so F = q (v x B) . Right hand thumb to the right, index finger out of the paper pointing to your nose: middle finger points in the direction of F.
F is perpendicular to v, so no change in magnitude of v, only in direction. And this remains so: , |v| constant, |F| constant and ##\vec F \perp \vec v##. The sure sign of a path that is characterized by a radius (what a giveaway in the original problem tekst!), for which we know (right?) F = mv2/R. So there is your ## R={mv\over QB}##. As long as you have no clue about m, no value for R.
To collect 3 Coulomb of charge you need at least 6 x 1018 protons and a lot of energy to squeeze them together. That many protons still is only 10 nanograms, though. But to avoid instant discharge by a lightning flash you need a substantial charge carrier. A 1 meter conducting sphere has a capacitance of 1 ##\mu##F, with 3 C the surface potential is 3 x 109 Volt. 4 Tesla of nicely homogenetic magnetic field isn't all that trivial either and barely possible above the, say, 1 m2 scale. (Others will correct me if I am wrong).
I think this is just a physics thought exercise and somewhat not-good: good students get distracted by the missing of m and average students put m=1 kg or something arbitrary.
I was triggered by this thread because as a 17 year old I had an oral grammar school exam where they put a Teltron tube in front of me that I had never seen before. The thing measures e/m as a ratio, using your formula. But googling 'e over m experiment' shows that JJ Thomson stole the cake in 1897.
Thank you both!
Eureka! Two equations, two unknowns!
Must say I don't understand kine's eureka. Do you, Ivan ?
  • · Replies 31 ·
  • · Replies 21 ·
