Which Particular Solution Matches y''+4y=2sin(2x)+e^{2x}+2?
  • Thread starter Thread starter shiri
The forum discussion centers on finding the particular solution for the differential equation y'' + 4y = 2sin(2x) + e^{2x} + 2 using the method of Undetermined Coefficients. The correct homogeneous solution is yh = c1cos(2x) + c2sin(2x), derived from the characteristic equation r^2 + 4 = 0, yielding complex roots. The particular solution yp must include terms like Axcos(2x) and Bxsin(2x) due to the presence of sin(2x) in the non-homogeneous part, leading to the conclusion that the correct form of yp matches option C) C1xcos(2x) + C2xsin(2x) + C3 + C4e^{2x}.
  • Understanding of second-order linear differential equations
  • Familiarity with the method of Undetermined Coefficients
  • Knowledge of characteristic equations and their solutions
  • Ability to differentiate and integrate exponential and trigonometric functions
  • Study the method of Undetermined Coefficients in detail
  • Learn how to derive homogeneous solutions for second-order differential equations
  • Explore the implications of complex roots in differential equations
  • Practice solving various forms of non-homogeneous differential equations
Students and professionals in mathematics, engineering, and physics who are solving differential equations, particularly those focusing on methods for finding particular solutions.
shiri
Consider the equation y''+4y=2sin(2x)+e^{2x}+2. According to the method of Undetermined Coefficients, the particular solution has the form:
C1 = 1st constant
C2 = 2nd constant
C3 = 3rd constant
A) C1xsin(2x) + C3x + C4xe^{2x} + C5xe^{-2x}
B) C1sin(2x) + (C2)2 + C3xe^{-2x}
D) C1cos(2x) + C2xsin(2x) + C3 + C4xe^{2x}
Solution:
y^2 + 16 = 0
y = -4, 4
yh = c1cos(x) + c2sin(x)
yp = Acos(2x) + Bsin(2x) + C + De^{2x}
y'p = -2Asin(2x) + 2Bcos(2x) + 2De^{2x}
y''p = -4Acos(2x) - 4Bsin(2x) + 4De^{2x}
y'' + 4y = 2sin(2x) + 2 e^{2x}
[-4Acos(2x) - 4Bsin(2x) + 4De^{2x}] + 16[Acos(2x) + Bsin(2x) + C + De^{2x}] = 2sin(2x) + 2 + e^{2x}
12Acos(2x) + 12Bsin(2x) + 20De^{2x} + 16C = 2sin(2x) + 2 + e^{2x}
cos(2x) ===> 12A = 0 ===> A = 0
sin(2x) ===> 12B = 2 ===> B = 1/6
16 ===> 16C = 2===> C = 1/8
e^{2x} ===> 20D = 1 ===> D = 1/20
So far what I got B) as a right answer, but I'm not too sure about A), C), and D)
Can anybody help me out here, please?
Check your work. Your homogeneous solution is wrong, which is causing your particular solution to be wrong as well.
Also, you have y2 + 16 = 0 right at the start of your solution section. I guess this is your auxiliary equation, but it doesn't have anything to do with this problem.
Bold: Changes
Solution:
y^2 + 4 = 0
y = -2i, 2i
[-4Acos(2x) - 4Bsin(2x) + 4De^{2x}] + 4[Acos(2x) + Bsin(2x) + C + De^{2x}] = 2sin(2x) + 2 + e^{2x}
0Acos(2x) + 0Bsin(2x) + 8De^{2x} + 4C = 2sin(2x) + 2 + e^{2x}
cos(2x) ===> 0A = 0 ===> A = 0
sin(2x) ===> 0B = 2 ===> B = 0
16 ===> 4C = 2===> C = 1/2
e^{2x} ===> 8D = 1 ===> D = 1/8
Am I doing this right, vela?
No. Your homogeneous solution is still wrong. First, you solved the characteristic equation incorrectly. Second, the roots you did find don't appear in the homogeneous solution. The whole reason to find the roots is to determine what the homogeneous solution is.
Side note: You shouldn't write y2+4=0 because the symbol y already stands for the function you're looking for. You should use a different variable in the characteristic equation, e.g. r2+4=0.
so it should be like this yh = c1e^{2x}+c2e^{-2x} ?
Update: I made an error on the equation from a 1st post. It was suppose to be
I forgot to put an addition sign between 2 and e^{2x}
No, it shouldn't.
The homogeneous equation is y'' + 4y = 0. The characteristic equation is r2 + 4 = 0. Vela's remark about using a different variable in the characteristic equation is one you should heed.
The solutions to the characteristic equation are r = +/- 2i. Vela remarked that you didn't have the right solutions, but you edited your work, so I can't tell if he was talking about something you had that you changed.
Since the roots of the char. equation are +/- 2i, you could have as your homogeneous solution yh = c1e2ix + c2e-2ix, but it's much more convenient to use yh = c1cos(2x) + c2sin(2x) and not have to worry about imaginary parts.
Now, for your particular solution. The problematic part is the sin(2x) term. The other two are straightforward. Since your homogeneous solution already has a sin(2x) term (and a cos(2x) term), what you need for the sin(2x) term on the right side is two terms: xcos(2x) and xsin(2x). This means your particular solution will start off with 4 terms.
Mark44 said:
No, it shouldn't.
yh = Axcos(2x) + Bxsin(2x) + C + De^{2x}
y'h = Acos(2x) - 2Axsin(2x) + Bsin(2x) + 2Bxcos(2x) + 2De^{2x}
y''h = -2Asin(2x) - 2Asin(2x) - 4Axcos(2x) + 2Bcos(2x) + 2Bcos(2x) -4Bxsin(2x) + 4De^{2x}
y''h = -4Asin(2x) - 4Axcos(2x) + 4Bcos(2x) - 4Bxsin(2x) + 4De^{2x}
y'' + 4y = 2sin(2x) + 2 + e^{2x}
(-4Asin(2x) - 4Axcos(2x) + 4Bcos(2x) - 4Bxsin(2x) + 4De^{2x}) + 4(Axcos(2x) + Bxsin(2x) + C + De^{2x}) = 2sin(2x) + 2 + e^{2x}
4Bcos(2x) - 4Asin(2x) + 4C + 8De^{2x} = 2sin(2x) + 2 + e^{2x}
sin(2x) ===> -4A = 2 ===> A = -1/2
cos(2x) ===> 4B = 0 ===> B = 0
4 ===> 4C = 2 ===> C = 1/2
So is that mean C) and D) from the first post are true?
anyone?
No, C and D are different. The particular solution has the form of one of them and not the other, so they can't both be the right answer. By the way, is one of the terms in C supposed to have a cosine? The first and second terms are of the same form otherwise.
oops...the first term in C) was suppose to be cosine
so according to my work (post #8), the answer is C) right?
For this question, you don't need to actually solve the problem. It's just asking you what the particular solution should look like. Now you wrote:
shiri said:
yp = Axcos(2x) + Bxsin(2x) + C + De^{2x}
which is correct. Which choice does yp match?
thanks vela!
I got another question I want to ask. It is same as the first post but this question had a different equation
y'' - 16y = 4cos(4x) + 4 +e^{4x}
The particular equation for this question is
C1cos(4x) + C2sin(4x) + C3 + C4xe^{4x}
right?
shiri said:
thanks vela!
right?
Yup!
12K
13K
