Passing a current from a metal wire through an electrolyte solution
Current can flow through an electrolyte solution, such as potassium chloride, due to the movement of ions rather than electrons. When a silver wire is submerged in this solution and a voltage is applied, positive ions (cations) migrate toward the negative terminal, while negative ions (anions) move toward the positive terminal, creating an electric field. The process involves the reduction of a chemical species in the solution, facilitating current injection into cells. Understanding the roles of ions and the electric field is crucial for grasping how current is effectively delivered in such setups. The discussion highlights the distinction between electron flow in metals and ionic movement in electrolytes.
sceptichymist
I am having trouble understanding how current can move through an electrolyte solution that does not contain ions of the metal of which the electrode supplying the current is made. For instance, if a silver wire were submerged in a solution of potassium chloride and, how would current pass into the solution?
I am in a neurobiology lab and we use glass electrodes containing a silver wire in a potassium chloride solution to inject current into living cells. I have been struggling to understand how it is we are doing so. Any help would be appreciated.
Electrons don't care what material they are in. As long as there is a low enough resistance or high enough voltage, they will move. Can you tell us what you do know about electricity? That way we can respond appropriately.
There is little or no electron flow in such solutions. What you have is a ionic solution, the Cl and K ions exist separately in solution. The positive ions will migrate to the negative terminal and the negatives will go to the other. This is due to the electric field in the solution. Seems to me you could be evolving Cl gas a one terminal. Note that my chemistry is ancient so I cannot tell you which, Cl or K, is positive or negative, I cannot tell you exactly what is going to happen. If Borek comes in he will be able to fill in the details.
I know that the carriers of charge that move through a metal wire are electrons. I know that the magnitude of current is directly proportional to the magnitude of electric potential difference between the two points it is moving and inversely proportional to the resistance of the material through which it is moving. Also, the carriers of charge responsible for current moving through an electrolyte solution are not lone electrons, but rather atoms with charge imbalances (ions). When an electrode is submerged in a solution and an external voltage drives a current into the electrode, one of the chemical species in the solution is reduced. Often, I have encountered examples of electrodes in solutions containing ions of the electrode, i.e. a copper electrode in a solution of copper II sulfate. What I don't know is, in my example in my original post, what is reduced, and how are we injecting current into the cells?
Ah ok, my mistake. I neglected to pay attention to the electrolyte part.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
