Path difference between the waves
10 replies · 2K views · last reply
toforfiltum
Physics exam diagram of two radio telescope dishes on a ground line separated by distance d, receiving parallel waves from a distant source at angle θ to the horizontal dashed line. Multiple-choice options A d sin θ, B d cos θ, C d sin θ over λ, D d cos θ over λ.
I formed a right angle triangle between the arrow downwards,d, and perpendicular line x from arrow. As such, sin θ = x/d.
x= d sinθ
path difference: d sinθ/λ
My answer is C, but answer is B. Where did cos θ come from?
Looking at the figure, in which case would you expect it to be no difference in path length?
Your description of how you formed your triangle is not very rigorous, so I may be misinterpreting what you've described. That said, I think you've allocated angle ##\theta## to the wrong corner of your triangle.
Perhaps you could sketch your construction on the image and post the result?
Is it when the waves are received at angle perpendicular to the horizontal?
Which corresponds to which value of θ?
90°?
Hand-drawn right triangle with a right-angle mark at the top vertex, the hypotenuse labeled x, the base labeled d, and the angle at the bottom left labeled theta.
I did it this way, but I think now I'm wrong to assume that x is parallel to the wavelength, right?
You've drawn the correct triangle but as you say, you've chosen the wrong "leg" for x. You want the leg that lies along the wave's path.
Diagram of two satellite dishes on the ground a distance d apart, receiving parallel incoming waves at angle θ to the horizontal, with a right-angle marked where a wave path meets a perpendicular line to the other wave.
Ah, I see now why it's cos θ. But, why it is not D now? Shouldn't path difference be expressed in terms of fraction of wavelengths?
In this case the path difference is just the length, otherwise the problem would have specified to express it in terms of wavelengths.
Ok. Thanks!
