Path difference from two speakers in phase at 600 Hz
6 replies · 2K views · last reply
Ajaroy
1. Homework Statement
Two speakers S1
and S2 derived by the same amplifier and placed at y=1
and y = - 1.The speakers vibrate in phase at 600 Hz. A man stands on the x-axis at a very large distance from the origin and starts moving parallel to the Y - axis. The speed of sound in air is 330ms-1
n0uUniV6yEd93cUC2
AF1QipPuNLxsrxJJA7P97xvzhMWBQ6SCtYvv56G8wsSD
at what angle will the sound drop to a minimum for the first time?
as minimun occurs at destructive interferenc
Δx = S2Y - S1Y = (2n-1)λ/2
for the first minima Δx = λ/2
but how to calculate Δx in terms of θ ,i an not able to from the geomentry of problem[/B]
Hi Ajaroy and welcome to PF.
Make a drawing. The man is moving parallel to the line joining the two speakers. To find Δx formally you need to use the Pythagorean theorem. You also need to consider that he is far from the speakers, so some kind of approximation will be required in terms of his angular displacement from the x-axis.
Two speakers S1
n0uUniV6yEd93cUC2
drop a normal from s1 on s2 Y ...the angle between s1-s2 line and the normal is say theta then its the angle between the normal to s1 s2
and the radial line to Y...this i am saying as x is very large compared to s1 s2 length.
so theta = Y/x and nearly equal to sin(theta)= (s2Y- s1y) /s1s2 as theta is small.
What are X and Y
Als how sin theta = y/x
I drew a perpendicular from Y to s1 s2line
Ajaroy said:
s2line
Then by Pythagoras theorem
OY2+OS12=S1Y2
And
OY2+OS22 =S2Y2
Then by solving
(OS1 +OS2) *2/S2Y+S1Y = DELTA X
What should I do nnex?
Ajaroy said:
What are X and Y
Oh!
Thanks I got it
