Path of an object at the vertex of an equilateral triangle
The problem involves three objects located at the vertices of an equilateral triangle, which begin moving towards each other at the same speed. The discussion centers on describing their paths and the time it takes for them to meet, while also considering the implications of their motion in terms of vectors and geometry.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the nature of the motion, questioning the initial conditions and the forces involved. There are attempts to formulate the problem using vector equations, with some participants expressing confusion about the relationships between velocities and distances. Others suggest visualizing the motion and breaking down the problem further.
The discussion is ongoing, with participants exploring various interpretations of the problem. Some guidance has been offered regarding vector formulations and potential mathematical approaches, but there is no consensus on a specific method or solution yet.
There is a lack of clarity regarding the initial conditions and the nature of the motion, as well as the definitions of certain variables like distance and velocity. Participants are also considering the implications of constant speed and the geometric configuration of the triangle.
chaoseverlasting
There are three objects at the Vertices of an equilateral triangle that start movin towards each other at the same time with a speed v.
Describe the path of the objects and the time taken for them to meet.
V1=v3 - v2
Where all velocities are in vectors.
The points moving towards each other will intersect at the Center of the triangle.
Velocity along the direction to the Center is vcos60 which will be he velocity at which he points move towards the Center.
The distance to be covered is d/sqrt(3).
This gives you the distance and time taken to cover it.
However, I'm struggling to formulate the problem in terms of vectors.
If point a moves towards point b by a distance dr (vector) in a time dt, I get stuck in trying to develop a vector equation for the path point a takes...
I've been struggling with this for about an hour now, but seem to be missing a connection.
Please help.
Thanks!
Hello chaos,
Is that all the information you have available ? I mean, they start moving, so I take it that theinitial velocity is zero. But what about the cause of the motion ? Mutual attraction, r does someone/somethig give them a kick ? Do they start moving towards each other all with the same speed ?
Sorry, they all move with constant and same speed.
There is no force / acceleration at play.
This the basic idea ? i.e. that e.g. a moves towards c with the same velocity as towards b (i.e. over the perpendicular in the middle of bc ?)
It should be clear that ##v_c \ne v_a - v_b##, so what is the meaning of the relevant equation ?
Where does the ##v\cos(60^\circ)## come in ?
"distance to be covered is ##d/\sqrt 3## " -- what is d ?
What is the complete problem statement ?
So each of the points moves along the edge of the triangle towards the next point.
This, point a moves towards point b which moves towards point c.
As they always move towards the next point with the same speed, they always form the vertices of an ever smaller equilateral triangle and converge at the Center.
D would be the length of the side of the initial equilateral triangle.
Ah, so we have a dog chasing hare(*) kind of thingy ! Like below ?
(*) actually, no: dog chasing hare let's te hare run straight -- yields a radiodrome, hefty mathematics
Yes!
Its the math of it that I'm trying to figure out.
The thought process escapes me.
I think I'll just have to break it down a lot more.
Any approaches you'd suggest?
You posted in introductory physics. What level of math are we at ? Do the differential equations in the link give you enough handle to set up such equations for the case at hand (hare path also curved ?)
Just so you are warned: I have no idea what comes out mathematically.
Doing it numerically (this is excel ?:)) at least gives nice pictures :rolleyes:
So, the math itself in the links is alright.
I'd like to develop the equations themselves.
I was getting stuck with the velocity vs path vector stuff. What route of analysis should I take?
Also, how did you generate the graphs in excel?
More or less by hand o0) .
a,b,c are x and y positions. point a is repeated to close the triangle ab bc ca
##\vec v_a = \left [ \left (\vec b_x -\vec a_x \over |\vec b -\vec a| \right ) |v| , \left (\vec b_y -\vec a_y \over |\vec b -\vec a| \right ) |v| \right ] ## etc.
and
##\vec a(t+\Delta t) = \vec a + \vec v_a \Delta t ##
Are you sure? But as you say it is a constant, so you can write down the distance from the centre at time t. Can you do something similar for tangential motion and obtain a path in polar coordinates?
26K
  • · Replies 27 ·
11K
